If i buy the 6p do i need to contact sprint to get it changed over or can i just swap the sim card in it?
Printable View
Should just be able to swap the SIM card and go :).
I would also recommend not "swamping" with your shiny new phone. :-)
And yeah, everybody gets all worried and worked up over "activating" their new phone and what the carrier will do. In most cases now a days just think of the carriers being responsible for the sim card and that's it. If you having a working sim card just put that bad boy in whatever phone it will fit in, regardless of the operating system and you're good to go.
You should be able to swap sims.. Or may be you will have to activate / swap online.
Worst case scenario is you will have to call Sprint.. Very worst case is that the SIM you have is incompatible. Don't know if it is the same SIM as the Nexus 6 or not.
Simply swapping the SIM will not work. You'll have to swap the ESN online or over the phone.
The N6 sim should work in this phone, it's a nano sim. However you'll have to switch the MEID online, or go to a sprint store and they'll do it for you.
