1. edwarto#CB's Avatar
    If i buy the 6p do i need to contact sprint to get it changed over or can i just swap the sim card in it?
    10-01-2015 12:18 PM
  2. Almeuit's Avatar
    Should just be able to swap the SIM card and go .
    Laura Knotek likes this.
    10-01-2015 01:02 PM
  3. So Cold's Avatar
    I would also recommend not "swamping" with your shiny new phone. :-)
    And yeah, everybody gets all worried and worked up over "activating" their new phone and what the carrier will do. In most cases now a days just think of the carriers being responsible for the sim card and that's it. If you having a working sim card just put that bad boy in whatever phone it will fit in, regardless of the operating system and you're good to go.
    10-01-2015 01:45 PM
  4. puch96's Avatar
    You should be able to swap sims.. Or may be you will have to activate / swap online.
    Worst case scenario is you will have to call Sprint.. Very worst case is that the SIM you have is incompatible. Don't know if it is the same SIM as the Nexus 6 or not.
    10-01-2015 02:03 PM
  5. flychinook's Avatar
    Simply swapping the SIM will not work. You'll have to swap the ESN online or over the phone.
    10-02-2015 12:41 AM
  6. maverick7526's Avatar
    The N6 sim should work in this phone, it's a nano sim. However you'll have to switch the MEID online, or go to a sprint store and they'll do it for you.
    10-02-2015 01:03 AM
  1. Cases for the Nexus 6P
    By Brent Zaniewski in forum Google Nexus 6
    Last Post: 09-09-2017, 01:05 PM
  2. Is it time to reconsider gun control?
    By Fairclough in forum Politics
    Last Post: 10-06-2015, 08:52 AM
  3. How can I edit contacts photos on a Samsung A3?
    By AC Question in forum Samsung Galaxy A3
    Last Post: 10-02-2015, 03:12 AM
  4. How to Correctly Root a Galaxy Mesmerize..... SCH I500
    Last Post: 10-02-2015, 12:36 AM
  5. How do I post a thread on the Marketplace?
    By vnlatn in forum General Help and How To
    Last Post: 10-02-2015, 12:10 AM
