12-18-2016 06:29 PM
31 12
tools
  1. AC Question's Avatar
    I would like to hook up my Nexus 6p to my television, does it have an HDMI output or is there another way I can connect my phone and television?
    10-08-2015 09:25 AM
  2. Nexuslover27's Avatar
    Not sure if the phone has HDMI output, but you can buy a Chromecast (which plugs into the HDMI port on your TV) and cast stuff from your phone to your TV.
    silverdemon likes this.
    10-08-2015 09:30 AM
  3. anon(847090)'s Avatar
    Chromecast. for $35 you can mirror your phone and laptop(mac/windows/chrome OS)
    you also get additional casting benefit. why do wired when you can do wireless?
    Genetic likes this.
    10-08-2015 09:57 AM
  4. wunderbar's Avatar
    The answer is no. I believe they answered that in the AMA from last week.
    As said Chromecast is what you'll need.
    10-08-2015 09:59 AM
  5. bunique4life05's Avatar
    10-08-2015 12:42 PM
  6. GrooveRite's Avatar
    Can Chromecast stream 5.1 audio codecs from phone to HT receiver?
    10-08-2015 12:45 PM
  7. htowngator's Avatar
    There is a type-C to HDMI converter that Google is selling.
    https://forums.androidcentral.com/e?...token=-WzB6FAZ
    10-08-2015 02:58 PM
  8. Nexuslover27's Avatar
    https://forums.androidcentral.com/e?...token=E6mrpPR3
    That is for the Pixel though, not the 6P. The requirements say: "Your device must have a video enabled USB Type-C port, compatible with the USB Type-C alternate mode specifications for video". Also, the "Enjoy it with" section has just one device: the Pixel.
    10-08-2015 03:46 PM
  9. recDNA's Avatar
    Will chromcast broadcast Netflix at full 1980 x 1020?
    Genetic likes this.
    10-08-2015 06:12 PM
  10. dflores's Avatar
    Yeah, it'll do 1080p with Netflix.
    10-09-2015 11:16 PM
  11. flychinook's Avatar
    Lack of HDMI output is the only thing that gives me pause about getting this phone. I have a mini projector that I use regularly hook up to my G2 with a slimport adapter. Yes, there's Chromecast, but that's a pain to use in hotels or out camping.
    10-11-2015 10:15 PM
  12. recDNA's Avatar
    Agreed. My note 3 has nice hdmi out but netflix app only 720p so netflix tells me to buy note 5 except note 5 has no hdmi out! Chromcast has its own problems. I just want netflix through app at 1080p and hdmi out at 1080p
    10-16-2015 02:19 PM
  13. Skeptic Spartan's Avatar
    Yes it does thru a MHL adapter. The Nexus 6P does do HDMI out.
    12-25-2015 10:46 AM
  14. RHChan84's Avatar
    Didnt work for me. Although I did use a USB-c to Micro USB adapter. But I have use that adapter to try it. I use it all the time for data transfer without issues.
    Nexus Six P
    12-25-2015 10:59 AM
  15. rhea's Avatar
    Please read through this sub-forum (http://forum.xda-developers.com/nexu...er-6p-t3224011) to get more info. AFAIK, 6P won't work with MHL; excepting Chrome books, the last device from Google that used MHL was the Galaxy Nexus. I could be wrong so I'm sending you to another source for more info.
    12-25-2015 11:36 AM
  16. krisiskris's Avatar
    Tried connecting my Nexus 6P up to my TV with the USB-C to HDMI adapter from the Google Store. Doesn't work! Nothing happens when connecting and can't find any options in the phone that might enable HDMI output
    02-23-2016 02:02 PM
  17. bjrosen's Avatar
    No it doesn't and it's absolutely unnecessary. If you want to connect to your TV just cast to it. A Chromecast will allow you to cast anything to your TV, basically the TV mirrors the phone screen. If you have a smart TV you don't even need a Chromecast, you can cast directly to it with Allcast and apps like Netflix and Youtube will couple to the TV's Netflix and Youtube apps allowing you to control them with the phone but playing through the TVs Ethernet or WiFI connection.
    02-23-2016 02:33 PM
  18. PhiPsi32's Avatar
    FYI there is a Tap 10 promo on Android Pay that gets you a free Chromecast with 10 AP transactions by the end of the month. Available to certain customers in the USA AFAIK.
    02-23-2016 11:42 PM
  19. icwhatudidthere's Avatar
    Maybe unnecessary for you. But HDMI is still easier for travelling if you don't want to bother setting up a network and just wanna watch a few shows on the TV. It's also handy for quick presentations at a remote office or playing a video clip at a friend's house and you don't wanna bother hooking up to Wifi and having to reset a Chromecast. Heck, some offices won't let you on their Wifi anyway.
    Moot point anyway, because the 6P is useless in those situations.
    02-24-2016 01:50 AM
  20. bjrosen's Avatar
    A Chromecast will do everything an HDMI cable does, it's cheap ($35) and it's more convenient. It plugs into the same HDMI connector on the TV and if you are giving presentations you can stand anywhere in the room while you are speaking because you won't be tethered to the TV by a short HDMI cable.
    02-24-2016 12:51 PM
  21. RHChan84's Avatar
    Chromecast still needs am internet connection.
    Anyone that travels know how hotel wifis are managed and how to log onto them. Can't do it with Chromecast. In this case, HDMI cable is needed.
    02-24-2016 01:42 PM
  22. bleong1977's Avatar
    Has anyone tried using the 6p as a hotspot and connecting a Chromcast device through that network? It seems like it would work like that.
    Still not as easy as a cable though :-(
    03-22-2016 01:08 PM
  23. czaplin's Avatar
    I'm in the same boat. Last trip I was able to setup Chromecast to hotel network. But casting an hd movie resulted in horrible lag. Just didn't work.
    Therefore, I'm considering buying a travel router from Amazon and test the hd quality. If that won't work, I'll be force to take a 11" laptop with me with hdmi port.
    03-22-2016 10:08 PM
  24. RHChan84's Avatar
    Nope. Your still using hotel wifi which is usually slow so it will still lag. The only way it wasn't slow was using my mifi but it's limited data so I'm not going to use it and recently, i just canceled it since my work gave me one as well. But I never use my work one for personal so I haven't hooked up my Chromecast in a while to it.
    03-22-2016 11:09 PM
  25. paulmike3's Avatar
    Chromecast doesn't do 4K. HDMI is still very necessary. Nuff said.
    04-03-2016 12:25 AM
31 12
  1. Does the Nexus 6p camera have dual flash?
    By AC Question in forum Nexus 6P
    Last Post: 10-08-2015, 10:02 AM
  2. Replies: 1
    Last Post: 10-08-2015, 09:38 AM
  3. What type of casing is on the Nexus 6p?
    Last Post: 10-08-2015, 09:32 AM
  4. Is a factory reset the only solution to my pop up ad problem?
    Last Post: 10-08-2015, 09:23 AM
