1. madkoda12's Avatar
    Hey there guys, Just got my Nexus 6P and just finished the initial set up. I was going through the phone settings hoping to find somewhere to turn on battery percentage (is there an option for this?). When I click into the battery settings/stats the phone kind of freezes up and a notification comes up saying "Unfortunately, Settings has stopped." And then it goes back out to the settings page. Is anyone else having this issue?
    11-02-2015 08:54 PM
  2. mchockeyvette27's Avatar
    I'm not sure exactly why the battery stats would be freezing up like that. Maybe try a reboot first.
    As for percentage, there's a hidden settings menu called system ui tuner. To get to it, you have to hold down the setting cog in the notification pulldown. Let it spin for a couple seconds and let go. Then go to the settings app at the bottom and click on system ui tuner. There's a toggle for battery percentage in there.
    geekaren and qnet like this.
    11-02-2015 09:05 PM
  3. madkoda12's Avatar
    Thanks for the tip about the system UI tuner.
    I tried rebooting the phone and the battery settings still would freeze up on me. I am going to try and factory reset and hope that fixes whatever was causing the battery settings to freeze up.
    11-02-2015 09:13 PM
  4. mchockeyvette27's Avatar
    If you haven't factory reset already, I would first try clearing cache. Sometimes that can solve issues without needing to factory reset.
    11-02-2015 11:13 PM
  5. madkoda12's Avatar
    I factory reset it before I saw the cache clearing Idea and that seems to have fixed the issue I was having.
    AnnDroid likes this.
    11-03-2015 11:13 AM
  6. mchockeyvette27's Avatar
    Gotcha. As long as it worked! I'd say to always try clearing cache first before resetting, cause that can solve some issues without wiping data. For future reference I guess. Lol
    11-03-2015 12:20 PM
  1. Replies: 5
    Last Post: 02-11-2016, 04:08 PM
  2. Replies: 4
    Last Post: 11-07-2015, 12:17 AM
  3. Time/clock app question
    By agp423 in forum Android Apps
    Last Post: 11-06-2015, 01:27 PM
  4. random reboots and wifi issues
    By Edwill86 in forum Moto X
    Last Post: 11-03-2015, 07:16 PM
  5. Issue while watching videos
    By loosecannon45 in forum Nexus 6P
    Last Post: 11-02-2015, 08:01 PM
