6p failed the out of box update, stuck on outdated build.
anon(8938849)
219
The update that we get out of the box didn't apply to my phone. It downloaded, I tapped restart and install, it counted down to zero, then just went to the check for updates screen saying I was up to date. I'm stuck on build MDA89D and I still have no update.
Almeuit
Moderator Team Leader
Moderator
Apr 17, 2012
32,277
23
Same as mine. But you never got prompted for an update the first time you turned it on?
Nope. I went to About Phone > System Updates and told it to check .. after a few seconds it changed to the time I did it and said no updates available.
anon(8938849)
219
Huh ok weird. I don't know why it downloaded an update for me, it was like 43 MB. But I guess I'm not outdated at least. Still that update with the November security patch should be coming to us sometime.
iamloco724
152
There was someone else who said they got a notification of an update when they started the phone for the first time but then when they went to check again they couldnt get it back it might just be a false update for whatever reason
maxburn
973
These are likely the security updates, can be seen in about with the security date. I'm still showing D and October 1st. November is in the process of rolling out and it does seem to be a staged rollout.
hallux
Q&A Team
Jul 7, 2013
12,322
7
38
I'm not sure what it was. I applied the update before popping my SIM in, I'm on K with the Oct 1 security patch level.
Almeuit
Moderator
Apr 17, 2012
32,277
23
Just got mine.
DragnDon
