I randomly get my WiFi radio turned off.. I've checked the settings and I definitely have it set to always stay on.
Throughout the day at least once or twice I'll notice my WiFi is turned off. As soon as I either turn it back on or go into More Settings it connects... not sure if this is a software issue or I may need to submit for a replacement.
I also have been having a ton of issues connecting to my Zenwatch 2 using Android Wear. Randomly drops connection and then won't connect at all unless I turn Bluetooth on/off or restart the phone.
Had the same problem with pairing to my car this morning. Bluetooth was on but nothing was connecting until I manually turned it on and off.
I ordered the 6P 64GB on launch day and just got it about a week ago.
Wondering if others are having this issue or if I need to submit for a replacement via Google.
