1. getbretweir's Avatar
    I've always payed to replace my battery (Nexus 4) and wondered if most people make the same investment. I can't imagine keeping my 6p any less than 24-36 months (barring some unforeseen must have tech) and when degradation begins to become apparent I'm planning to get its battery replaced to.
    Has anyone done this in the past, and if so where do you take/send it and how much do you typically spend? So many people use it as a reason to replace their phone which seems crazy to me.
    12-05-2015 01:23 PM
  2. N4Newbie's Avatar
    As you can see in this video, opening the Nexus 4 and replacing the battery is relatively easy:
    The 6P, on the other hand, is quite a bit more difficult:
    Having said that, are you quite sure you aren't imagining the degradation of your battery after such a short time? I have owned Nexus 4, 5, 6 and now 6P and never felt the need to replace a battery in any of them.
    12-05-2015 02:49 PM
  3. getbretweir's Avatar
    my 4 didn't slow down THAT much but it definitely slowed down and I noticed a significant difference after replacing it. Keep in mind I almost kept mine for 3 years with constant use so it's not like I did it after 6 months.
    12-05-2015 06:55 PM
  1. Replies: 1
    Last Post: 12-10-2015, 07:30 AM
  2. Strange battery drain
    By Greenenvey in forum Moto 360 (2015)
    Last Post: 12-06-2015, 03:32 PM
  3. Nexus 5 battery dead due to automatic restart problem
    Last Post: 12-05-2015, 05:43 PM
  4. Cell standby and battery, help!
    By conan1071 in forum Motorola Droid Turbo
    Last Post: 12-05-2015, 11:05 AM
  5. My N4 gets hot and starts to deplete battery fast.....
    By TechnoFreak in forum Ask a Question
    Last Post: 12-05-2015, 07:42 AM
