1. dmlv's Avatar
    i've searched...went into "phone settings" and vibration for calls is unchecked but seems no way to prevent vibration with the vm notifications. I prefer just the simple sound.
    I am using the 6p w t-mobile and the built in vm feature is sweet. seems 6.0 has no separate setting for vm notifications.
    Am I missing something?
    12-06-2015 10:39 AM
  2. Cant Miss's Avatar
    Phone/Settings/Calls/Voicemail
    12-06-2015 12:16 PM
  3. dmlv's Avatar
    Did that long before asking. I have had vibrate unchecked. Still vibrates so must be a bug...
    Not the end of the world.
    Thanks
    12-06-2015 02:32 PM
  4. Cant Miss's Avatar
    You should report it so it hopefully gets fixed.
    12-06-2015 04:27 PM
  5. dmlv's Avatar
    I did... Thanks
    Wonder if 6.0.1 fixes the issue.
    12-10-2015 06:55 PM
  6. Cant Miss's Avatar
    Doubt it; guessing it has been in the can for at least a week or two.
    12-11-2015 12:56 PM
  7. Johnius's Avatar
    Sorry for the necrobump: settings>notifications>options (the three dots in the upper right)>show system.
    Then find the program that notifies you and block it.
    10-22-2016 07:49 PM
  1. How do I mark multiple emails read without having to hit each one?
    Last Post: 12-07-2015, 06:27 PM
  2. How do I clear up space on my phone?
    By FrumiousBandersnatch in forum Samsung Galaxy S5
    Last Post: 12-07-2015, 08:36 AM
  3. Can't find "notification access"
    By Tornike Dundua in forum Ask a Question
    Last Post: 12-06-2015, 10:36 AM
  4. Replies: 0
    Last Post: 12-06-2015, 10:12 AM
  5. Replies: 2
    Last Post: 12-06-2015, 09:59 AM
