1. AC Question's Avatar
    I want to buy a USB quick charger for my Nexus 6P.
    I also want a wall charger
    Both should be a supporting quick charge. Please suggest me few names
    12-10-2015 07:44 AM
  2. hallux's Avatar
    There are several threads about this in the Nexus 6P section of the forum, I suggest you browse those.
    Main forum section: Nexus 6P - Android Forums at AndroidCentral.com
    Charging threads:
    http://forums.androidcentral.com/nex...-new-post.html
    http://forums.androidcentral.com/nex...-chargers.html
    I also suggest you check out Benson Leung's G+ posts on USB-C chargers/cables. He has a Google Docs document posted with his testing results.
    https://plus.google.com/u/0/+BensonLeung
    You aren't going to get "quick charge" with the 6P, it does not support Qualcomm's charging spec for that. Instead, it uses the new USB Power Delivery spec to determine charge speed, and you SHOULD only get "Charging Rapidly" on the lock screen when using a proper USB-C charger and cable.
    12-10-2015 08:12 AM
  3. bjrosen's Avatar
    I disagree with Benson about cables that advertise higher charging currents, I would classify it as a feature not a bug. Technically he's right, the USB 3.1 spec clearly states that USB-A to USB-C cable should advertise 1.5A of charging current, not 3. However any decent charger is current limited so it won't deliver more current than it is rated for. I have a number of USB-A car chargers and they all have at least one port that's rated for 2.4A which they describe as a tablet port. I've measured the current using the Ampere app and indeed the 2.4A ports deliver about 2.4A when used with a non-compliant USB-A to USB-C cable. The 1.5A ports deliver 1.5A with the same cable. So my suggestion is that if your car charger isn't rated for 2.4A or better then you should buy one that is and use it with a non-compliant cable.
    12-10-2015 11:05 AM
  4. Almeuit's Avatar
    Please check out this thread - http://forums.androidcentral.com/nex...-charging.html.
    Thanks.
    12-10-2015 11:59 AM
  1. Replies: 1
    Last Post: 12-10-2015, 09:32 AM
  2. Looking for an economic app..
    Last Post: 12-10-2015, 09:09 AM
  3. Replies: 1
    Last Post: 12-10-2015, 09:07 AM
  4. Replies: 1
    Last Post: 12-10-2015, 07:05 AM
