1. kenorian's Avatar
    I have GSam Battery Monitor pro on my 6p running the latest Marshmallow.
    It shows that there is no data available for apps usage. I tried clearing the cache, then uninstalling and re-installing - same issue.
    Anyone else experiencing this?
    GSam Battery Monitor Not Showing App Usage (Nexus 6P + 6.0.1)-screenshot_20151215-100243.jpg
    12-15-2015 10:22 AM
  2. N4Newbie's Avatar
    Read the reviews and Play Store writeup. It apparently does not support Marshmallow.
    12-15-2015 12:20 PM
  3. PAC757's Avatar
    That's strange, I have GSam Pro on my Nexus 6 running 6.0 Marshmallow and it's working fine, the same as it did when I was on 5.1.1 Lollipop. I would write the developers and ask about it.
    12-15-2015 01:46 PM
  4. N4Newbie's Avatar
    That is strange, indeed. There are a number of current reviews for both the free and pro versions which state it does not work on the 6P and/or Marshmallow 6.0.0 and/or 6.0.1.
    https://play.google.com/store/apps/d...amlabs.bbm.pro
    Click Reviews and then select Newest from the dropdown.
    12-15-2015 01:53 PM
  5. PAC757's Avatar
    This is from just a few minutes ago also the about phone screen showing that the phone is running 6.0 Marshmallow.
    Attached Thumbnails GSam Battery Monitor Not Showing App Usage (Nexus 6P + 6.0.1)-1848.jpg
    12-15-2015 02:38 PM
  6. PAC757's Avatar
    GSam image
    Attached Thumbnails GSam Battery Monitor Not Showing App Usage (Nexus 6P + 6.0.1)-1847.jpg
    12-15-2015 02:39 PM
  7. kenorian's Avatar
    Thanks, saw that now....
    12-15-2015 02:43 PM
  8. N4Newbie's Avatar
    I wonder if it might be that you had GSAM installed previous to the Marshmallow update on your Nexus 6 whereas the 6P would have had to have been a fresh install on Marshmallow. It's possible that you snuck through with a permission that was already granted to GSAM under Lollipop but no longer accessible under Marshmallow.
    Just a thought.
    12-15-2015 02:48 PM
  9. Adamd1169's Avatar
    It hasn't been long enough since you unplugged it for it to gather any data.
    12-16-2015 01:19 PM
  1. Replies: 4
    Last Post: 12-30-2015, 02:00 AM
  2. Nexus 6P
    By mookiekillsit in forum Marketplace Archive
    Last Post: 12-16-2015, 04:08 PM
  3. Does the stock messaging app allow texting over wifi only?
    By Sgooter in forum Verizon Samsung Galaxy S4
    Last Post: 12-16-2015, 07:19 AM
  4. Replies: 2
    Last Post: 12-15-2015, 10:33 AM
