Originally Posted by
Carraser23 Does blocking calls also block messaging?
Firstly, what I love about this call blocking feature, you see with other phones or call blocking apps, what happens if a blocked number calls you is that for the caller, he hears that the call went through, rings once on his end then it shows BUSY. It is obviously that he was blocked. But with this Android Marshmallow call blocking, when the number tries to call you, it gives them a tone as if the number doesn't exist or is disconnected so it is very nice, doesn't make it very obvious that you are blocking them but makes them think there is a problem with the network or your line is disconnected.
Secondly, I just tried and the SMS won't go through from a number you have blocked, it says not delivered!
