Nexus 6P - Wirelessly Project The Phones Display?
Pirate Arr
131
I have a Samsung smart tv and recently wanted to wirelessly display my screen on it for a tv show (Game of Thrones if you must). Unfortunately whenever I go to the cast setting panel my tv titled Aryan is not listed nor is the option to enable wireless display in the menu (three dots) something that my Nexus 7 2013 and Nexus 5 have and they work perfectly to display their screen and I am disappointed that I don't seem to have the option on my 6P. Any solutions? Can't seem to get it and in fact neither can YouTube cast any videos to my Samsung tv while my Nexus 7 and 5 can including my other Vizio smart tv that my 6P cant. Any solutions? I've turned off my phone and back but I cant seem to make the option appear. Don't tell me Google removed Miracast support which in that case I'll have to use my Chromecast -.-. I very much dislike this and disappointed in Google
Posted via the Android Central App on my Frost Nexus 6P
cane prevost1
151
Projection from Phone?
Does anybody have a solution for projecting video from the phone without Wifi? Would be interested in a wired solution to an inexpensive projector if that's available? Is it possible to connect the phone to a projector via USB? Or is there a wireless option that doesn't require wifi? Thanks.
Evilnut
738
Re: Wireless Display
I think chromecast are still on sale in the Google store. I bought a dozen of them and gave them for Christmas presents. Everyone is absolutely in love with them! Even people that have smart TVs already. I've got them on all four of my televisions.
Via the Android Central App
anon(596177)
1,189
105
Re: Projection from Phone?
Your best option is going to be implementing a solution that makes use of the screen cast function of the phone, which, you guessed it, uses wireless. The USB c port on this phone does data transfer and charging. It will not do video streaming. Does the projector have an HDMI port on it? Get yourself a Chromecast and a wireless N or AC router. The router doesn't need to be connected to the internet as long as what you are casting is stored locally on your phone. Just set it up to give out dhcp address, connect both devices to it, and stream away.
DJ Sandman
102
I have dealt with Chromecast 1 & 2 and they were both tedious and cumbersome to say the least! I def. prefer wireless cast or MHL.
Almeuit
Moderator Team Leader
Moderator
Apr 17, 2012
32,277
23
I don't think I have ever seen an easier piece of tech like the Chromecast. You set it up on the wifi network and then pretty much just open apps and tap a button to have it thrown to the TV.
RHChan84
2,253
106
63
Chromecast works great at home. Hotels, not so much. I also wish it had MHL but I ended up picking up an HDMI adapter for my iPad and it works. And if frees up my phone go use for whatever.
Almeuit
Moderator
Apr 17, 2012
32,277
23
It works if you have WIFI. If you don't, then you have to use 2 devices to get it to work. I had the first version and the sound stopped working on the third attempt.
I have the second version and though I don't have WIFI where I live, I decided to kerp it once WIFI is available. I just wish that it didn't require WIFI.
Oh well yeah -- The device is meant to work on WiFi though so that is just a requirement / how it was built. Once you have that the device is very easy to use.
DJ Sandman
102
Sorry - I tried to edit my post but ended up deleting it. I just wanted to add to the wireless cast/MHL users.. I highly doubt that Google will ever update wireless cast or add MHL to Nexus phones thanks to their Chromecast.
So much for flexibility.
bjrosen
751
3
The Netflix app sees my Panasonic TV as well as my Chromecast. Allcast can play videos directly on my TV as well. Cast only works with Chromecast. I have a first gen Chromecast, it's always worked flawlessly. They cost almost nothing ($35) so there is no reason not ot get one.
Almeuit
Moderator
Apr 17, 2012
32,277
23
I don't believe they sold MHL cables even before it -- Usually people just snagged them from a 3rd party. I am sure once USB-C becomes more widely used on Android phones it will be easy to snag one.
Evilnut
738
I've never had a problem with any of my gen 2 Chromecasts. They work flawlessly and I got them on day one. I use them with my phone, tablet and Chromebook. I use mine in a hotel room with my hotspot and they work perfect. Super easy, works every time for me.
gamesnepal
18
I think that the only solution would be to use Chromecast. I don't even know whether those cheap Chinese casting devices even work. I was looking for this some days ago.
vzwuser76
1,669
26
I have an LG smart TV, so this may not be the same, but on mine I had to enable something like wireless display or something similar to that before it would work. On mine it's located in the settings under either display or connections IIRC. Maybe look through your TV's settings and see if there is a setting to enable it. Hope that helps.
Finsrepair
