So , after using iPhone6 Plus and iPhone6s Plus a while i decided to try out the Nexus 6P.
iOS vs Android discussion aside , i have noticed some noticeable differences after using my Nexus 6P for a few weeks that i am wondering if is normal or not as i have not used an Android/Nexus device for a long time.
I used my iPhones for web browsing on WIFI alot , and the battery life has been great for this use , i could use it quite heavily throughout the day , browse the web for a couple of hours in the evening and get anywhere between 40%-50% battery remaining at the end of the day.
But on the Nexus6P i noticed that the battery drains very heavily when browsing (could almost see it drop 1% every other minute), even when i had no apps installed, factory reset , screen turned down to 15-20% brightness , location/notifications off etc , is this normal on the Nexus6P ?
Other use didnt seem to drain the battery more than normal , just browsing with Chrome.
Aside from this i am really happy with the phone , screen is great & loving the phone overall.
