1. Haythom's Avatar
    Hello,
    I love the camera Of this Phone and It takes so good photos
    But my question Is : The quality of this phone will be the same and the same performance If I bought It from any country ?? I mean for example the camera will stay the same great quality as I can see here In the topic of Nexus 6p Photos ??
    Friend Of mine will buy It for me from Malaysia soon or It's better to order It from Europe ??
    Pety likes this.
    02-04-2016 04:33 AM
  2. hallux's Avatar
    Should be the same hardware.
    Haythom likes this.
    02-04-2016 07:15 AM
  3. Haythom's Avatar
    Yes It should be but It's for sure the same ? Or It can be not the same quality ?
    Anyone guys can confirm this to me ? specially the camera quality
    02-04-2016 07:52 AM
  4. bjrosen's Avatar
    The camera will be the same, the only thing that might be different are the radio bands although I think there are only two versions of that, US and everybody else, but I'm not sure if there are more variants then that. You should buy the phone directly from Google or Huawei so that you get a proper warranty.
    Haythom likes this.
    02-04-2016 08:17 AM
  5. Haythom's Avatar
    Yes I'm aware that there Is two versions of this phone North America version (A1) and Rest of World version (A2)
    I will get the one (A2) From Huawei In Malaysia but I was worry from the Camera quality to be not the same and the Phone in general not be the same performance like the one I get from Europe.
    02-04-2016 08:45 AM
  6. LeoRex's Avatar
    Both versions have the exact same hardware and software, other than the different radio bands that are supported (radio baseband). There will be zero difference in the overall operation of the phone, including the camera performance.
    Laura Knotek and Haythom like this.
    02-04-2016 09:04 AM
  7. Haythom's Avatar
    Thank you for your answer
    But my main question was If i bought version (A2) From Malaysia it will be the same performance and quality specially The camera like the same version (A2) that I can buy from Europe ? Or It will be not good like the one from Europe ?
    02-04-2016 09:54 AM
  8. hallux's Avatar
    LeoRex answered that question in the post that you quoted. Same hardware and software. Are you expecting that the devices that don't pass quality control but are "close enough" will get shipped to your country? Doesn't work like that.
    Haythom likes this.
    02-04-2016 10:12 AM
  9. Haythom's Avatar
    I was afraid and think that the phone can be not the same quality if I bought It from Malaysia or China and not like the same quality If I bought from Italy or Germany for example beacuse I think each country has different factories.
    02-04-2016 10:21 AM
  10. renegad3's Avatar
    Hello,
    What makes you think it would perform differently depending on where you buy it from?
    Its all made by the same manuf. and ships with the same software.
    Have you seen evidence anywhere that suggests it behaves differently when purchased from one region compared to another?
    Same hardware + same software = same performance, regardless of purchase region.
    Haythom likes this.
    02-04-2016 10:26 AM
  11. LeoRex's Avatar
    Ah... I see. There are plenty of products being sold that vary in quality and fit and finish based on where they are purchased. Too often, this is due to the product actually being a counterfeit knock-off of the actual product. There are a LOT of fake smartphones in the market today. I found a site a while back, wish I would have bookmarked it, but it had a bunch of fakes... Samsung Note 4's, iPhones, etc... all with extremely cheap hardware, shoddy materials, etc.
    The Nexus 6P is manufactured by Huawei... every Nexus 6P is manufactured by Huawei... and they are all made to the exact same specifications laid out by Google. One purchased in Kuala Lumpur should be exactly the same as one in New York, London, Mumbai or Sydney (other than the slightly different radio bands mentioned ealier).
    If it isn't... less RAM than it is supposed to, less storage or a different processor, etc. it's not authentic.
    Haythom likes this.
    02-04-2016 11:39 AM
  12. Zendroid1's Avatar
    Just don't buy a fake and you will get the same as everyone else.
    Haythom likes this.
    02-04-2016 12:23 PM
  13. Haythom's Avatar
    Thank you for your answer I was worry to buy It and found It not perform as It should be.
    Thank you so much LeoRex your reply answered all the questions
    02-04-2016 12:31 PM
  14. D13H4RD2L1V3's Avatar
    They have the same hardware regardless of variant.
    Haythom likes this.
    02-04-2016 05:54 PM
  1. Honor 5X Owners- Any Plans Dealing With The OS?
    By AC Question in forum Honor 5X
    Last Post: 02-09-2016, 09:37 PM
  2. Replies: 1
    Last Post: 02-04-2016, 12:51 PM
  3. Replies: 1
    Last Post: 02-04-2016, 05:44 AM
  4. Replies: 1
    Last Post: 02-04-2016, 04:13 AM
  5. Replies: 0
    Last Post: 02-04-2016, 01:01 AM
