If you've ever wanted to see the battery percentage remaining on your battery icon here's a quick way to get it without having to download any new software:
1. Swipe down to reveal your control center. Tap to open it. Find the gear icon and press and hold for about 5 seconds.
2. When you release you should see a popup that says that System UI tuner is enabled.
3. Go to your settings and scroll to the bottom. You will now find System UI tuner.
4. Open UI tuner and flip the switch for "Show embedded battery percentage" to on.
5. Profit.
5. Profit.
