1. dipkian08's Avatar
    Hi,
    I am able to see the data on the pen drive on my Nexus 6p and can play it , but when i try to transfer anything from my device to pen drive then i not able to do that .
    is there a way or app that can help me to achieve the same without rooting my device
    Please suggest ....
    Thanks in advance .
    03-07-2016 06:14 AM
  2. still1's Avatar
    r u using an app or Android's build in explorer? try using Solid Explorer app
    03-07-2016 03:35 PM
  3. dipkian08's Avatar
    I have tried many explorers. But none worked.
    03-07-2016 07:38 PM
  4. dipkian08's Avatar
    Is there anything that I need to change in my device settings ??
    03-08-2016 02:51 AM
  5. RHChan84's Avatar
    Try a different drive or reformat the drive.
    03-08-2016 06:34 AM
  6. dipkian08's Avatar
    I'll try this but the same drive I used in let 1s n it worked fine.
    03-08-2016 06:50 AM
  7. Slow_S10's Avatar
    Personally I have use ES file explorer with mine and it works great for reading and transferring files. I have a type-c micro SD card reader and a home made type-c flash drive (which is just a type C to A adapter with a tiny flash drive stuck in it) that I have been using in my 6P for months now with no problems.
    Also depending on the adapter you may have to select a different USB setting for it from the notification shade in order to use it properly. I know one of my adapters has to be in file transfer mode to work, and another one has to be in charging mode, which is weird but it works.
    03-09-2016 06:59 AM
  8. dipkian08's Avatar
    Solid file manager worked for me. Will buy the full version. I tried es file manager but it force closes every time I try to transfer data from phone to pen drive.
    Thanks @still1
    03-09-2016 09:56 AM
  1. Deepak Krishnappa from India, Hello to all of you !
    By Deepak-Krishnappa in forum New to the Forums? Introduce Yourself Here!
    Last Post: 03-29-2016, 05:34 PM
  2. How to turn camera stabilization feature OFF?
    By AC Question in forum Samsung Galaxy S5 Mini
    Last Post: 03-07-2016, 05:26 AM
  3. How to support otg pen drive in samsung galaxy e5
    Last Post: 03-07-2016, 05:20 AM
  4. Which UI element to use to display bulk text in Android?
    Last Post: 03-07-2016, 05:14 AM
  5. Why can't I move apps to my SD card?
    By Androidgirl03 in forum Displays
