1. AC Question's Avatar
    The position of the volume button on the Nexus 6P makes it easy to unintentionally raise or lower the volume. Is there a way to lock the volume.
    I realize I can be more careful when picking the phone up.
    03-10-2016 03:39 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! There's no native function for that. Try Volume Control.
    03-10-2016 05:08 PM
  3. stevenrt's Avatar
    There is also a program called Volume Locker. It will lock various volume settings, and if you try to change the volume, it pops up a window requiring that you confirm the change, otherwise it resets the volume to what it previously was.
    B. Diddy and anon(156377) like this.
    03-10-2016 06:50 PM
  1. Replies: 5
    Last Post: 09-26-2020, 10:13 PM
  2. Replies: 3
    Last Post: 03-24-2016, 11:50 AM
  3. Replies: 1
    Last Post: 03-10-2016, 05:23 PM
  4. Replies: 1
    Last Post: 03-10-2016, 05:16 PM
  5. Is it safe to disable all the Verizon apps?
    By felloffthetruck in forum Samsung Galaxy S7 edge
    Last Post: 03-10-2016, 04:05 PM
