I'm running 6.0.1 with March 1st security patch level. I do not use smartlock with any devices. My Nexus 6P is set up to unlock with either fingerprints or a pin. When I double tap the power button, the camera opens as do the soft key options. If I hit the home button, I get my home screen which completely bypasses my finger print and pin setup.
I disabled the double tap option which I thought would be a temp fix to secure the phone. But, when I swipe the camera icon on the lock screen, it will also bypass the security. So basically, my phone cannot be locked.
Anyone else running into this? Suggestions on how to fix?
Thanks-
Thanks-
