Originally Posted by
CHILLYWILL_95831 What I've noticed with the 6p is that the flash implementation in auto along with HDR auto makes for some really great exposures when the camera chooses to flash. The flash gives very natural exposures with that set up.
I've played around with HDR+ and the flash and I think I can see how that is. Typically, the camera starts to expose and fires off the flash... and takes one exposure. Now, depending on what you are shooting, you can end up with a picture that can be less than ideal.... something close gets overexposed and the background is gone because it was too dark compared to the relatively bright foreground.
HDR+ goes about things differently. It rips off several exposures (they don't fuss with the exposure between shots either) and then does some cool processing tricks (pixel level averaging, astronomy-style lucky image processing, etc.) So in those exposures to process, it'll have shots that have been exposed during the flash window and some when not. The trick is finding which situations would work best with the flash... I am guessing the most effective use would be if your foreground subject is much darker than the background.
