1. Mami Sazasaki android's Avatar
    Please just quick answer: Is this normal? used 10% battery in 30 mins.
    Info: I play game(Robbery bob, not heavy graphic, not light graphic) with my 6p, used 10% battery in 30 mins.
    (40% bright, 20% loud, no wifi,no data,no bluetooth,no location) Thanks a lot in advance.
    07-21-2016 08:22 AM
  2. Mami Sazasaki android's Avatar
    please just answer, guy. It is not that hard.?
    07-21-2016 08:45 AM
  3. Fericire's Avatar
    (I can't really answer because o don't own a nexus 6p but a nexus 4,
    for 30 minutes screen on time, playing a game, and 10% battery = 1% per 3 minutes,
    in my opinion i think that is decent/normal,
    after all it's a super big QHD display + snapdragon)
    07-21-2016 08:50 AM
  4. Mami Sazasaki android's Avatar
    Thanks a lot Fericire. Your reply is really big relief to me.
    However I need more person to give me more reply as this answer. So Pleaseeeeee.
    07-21-2016 09:11 AM
  5. terellw's Avatar
    You're on pace for 5 hours screen on time, which is definitely solid
    07-24-2016 04:38 PM
  6. terminator y2k's Avatar
    Yes.
    *6P 64 gb Graphite (AT&T)*
    *iPad Air 2 64 gb Space Gray (AT&T)*
    07-25-2016 12:41 PM
  7. tonyr6's Avatar
    Try not using it for an hour or longer to see if you have any wake lock draining issues?
    07-25-2016 03:33 PM
  8. TGIS's Avatar
    Seems about normal, if not slightly bad
    07-29-2016 04:34 PM
  1. Replies: 2
    Last Post: 08-20-2016, 08:52 AM
  2. Replies: 1
    Last Post: 07-26-2016, 10:15 AM
  3. Replies: 4
    Last Post: 07-21-2016, 05:05 PM
  4. Replies: 1
    Last Post: 07-21-2016, 08:27 AM
  5. HTC One M8 stuck on boot screen can't close it?
    By AC Question in forum HTC One M8
    Last Post: 07-21-2016, 07:43 AM
