I've been noticing Android OS and Android System are so high up on my battery. I know this has been a problem since the developer previews but why?
I had to a full nuclear factory reset. Not only did I have Wifi issues with it not connection or disconnecting when sleeping. I factory reset and set it up as a new device did not restore from a backup. I had to reconfigure all my apps again. The only backup I was able to restore was Nova Launcher which I exported. Everything else was from scratch. Now Wifi stays connected and Doze is working.
Also setting up from scratch I was able to avoid installing the useless drain apps like Fit during setup it asked me what Google apps I want so I only chose Notes because I use it. Still forced to install Play Music, Movies app though but no Books app either.
I had great battery life on the previews, but now I was down to 50% at lunch time (normally in the ~75% range) and hadn't done anything out-of-the-ordinary (actually less use today than most days).
I just cleared my cache partition via recovery and I'm charging it now. Hopefully this clears up the issue, but if not, I'm sure Google will patch it sooner or later.
Did you restore from a older backup or set it up as completely new? I had to set it up a a new device. The only thing I imported from a backup was my Nova Launcher and Power Toggle settings.I did a factory reset as well, but I'm still getting the battery drain and doze not working.
Was fine on the previews, seems much worse now. Has anyone tried a factory reset? If so did it help?
Did the cache wipe help?
Just wondering, anyone here connect to 5ghz signal on wifi? I have been having issues with Doze and last night, I switch to 2.4Ghz and Doze worked perfect last night with 2-3% drain 8 hours. When I was connected to 5Ghz, I would get 20% drain.
