10-21-2016 07:23 PM
30 12
tools
  1. TheWillOfSon's Avatar
    I've been noticing Android OS and Android System are so high up on my battery. I know this has been a problem since the developer previews but why?
    08-23-2016 11:33 PM
  2. Ev0d3vil's Avatar
    I suspect it's a Google server side issue. I've been having this since MM Aug update.
    08-23-2016 11:40 PM
  3. allen832008's Avatar
    I wasn't seeing this on the previews, but really seeing it now with the official update.
    08-24-2016 11:16 AM
  4. dty06's Avatar
    I had great battery life on the previews, but now I was down to 50% at lunch time (normally in the ~75% range) and hadn't done anything out-of-the-ordinary (actually less use today than most days).
    I just cleared my cache partition via recovery and I'm charging it now. Hopefully this clears up the issue, but if not, I'm sure Google will patch it sooner or later.
    08-24-2016 12:44 PM
  5. trojanman's Avatar
    At least after my first full day yesterday on Nougat, I'm experiencing the opposite. Battery life has improved for me, and the new doze is working pretty well. Currently sitting at 89% and it's been unplugged for about 11 hours...granted, most of the time was overnight and I haven't used it much at work. Android System and Android OS usage are both at 2% each.
    08-24-2016 01:05 PM
  6. anon(5506951)'s Avatar
    Currently at 66% battery with 2:30 SOT. Android System is at 5%, OS is at 4%. On M, those would consistently be at 1%. Come on, Google...
    08-24-2016 01:26 PM
  7. tonyr6's Avatar
    I had to a full nuclear factory reset. Not only did I have Wifi issues with it not connection or disconnecting when sleeping. I factory reset and set it up as a new device did not restore from a backup. I had to reconfigure all my apps again. The only backup I was able to restore was Nova Launcher which I exported. Everything else was from scratch. Now Wifi stays connected and Doze is working.
    Also setting up from scratch I was able to avoid installing the useless drain apps like Fit during setup it asked me what Google apps I want so I only chose Notes because I use it. Still forced to install Play Music, Movies app though but no Books app either.
    08-24-2016 05:45 PM
  8. CHILLYWILL_95831's Avatar
    I did a factory reset as well, but I'm still getting the battery drain and doze not working.
    08-28-2016 08:56 AM
  9. CHILLYWILL_95831's Avatar
    Did the cache wipe help?
    08-28-2016 08:57 AM
  10. tonyr6's Avatar
    Did you restore from a older backup or set it up as completely new? I had to set it up a a new device. The only thing I imported from a backup was my Nova Launcher and Power Toggle settings.
    08-28-2016 09:04 AM
  11. bjrosen's Avatar
    Was fine on the previews, seems much worse now. Has anyone tried a factory reset? If so did it help?
    08-28-2016 09:45 AM
  12. CHILLYWILL_95831's Avatar
    I did a factory reset after N install to make sure i had a clean version, no file corruption, and still had the drain issue. However, I've done a cache wipe since this post and it seems that my device is properly dozing again. We shall see.
    08-28-2016 12:28 PM
  13. CHILLYWILL_95831's Avatar
    I restored from the previous backup because I had no battery drain issues. This phone is still under a one year factory warranty, so I'll definitely contact Google if the problem persists. I've been losing 50%battery within 3 hours time with an hour of sot. Something's definitely not right.
    08-28-2016 12:31 PM
  14. dty06's Avatar
    Doesn't seem like it has. I was at 70% at 10AM this morning after fairly heavy use (playing a game but less than an hour SOT).
    Fortunately, I have a charger at work, so there's no issue for me, but it would not last a full day if I didn't. Wouldn't last until 2pm at that rate.
    08-29-2016 10:02 AM
  15. PhiPsi32's Avatar
    The main issue I have is the new app permissions. Gsam can't track battery usage by individual app. It can only give me an aggregate figure. So I know that apps are taking 68% of the power usage but I can't tell if any one app is draining my battery.
    08-30-2016 01:09 PM
  16. Ron Copsetta's Avatar
    This is mine after 1 hr, been running nougats final build for about a week
    Attached Thumbnails Android Nougat Battery Issues-screenshot_20160902-090209.jpg
    09-02-2016 08:06 AM
  17. RHChan84's Avatar
    Just wondering, anyone here connect to 5ghz signal on wifi? I have been having issues with Doze and last night, I switch to 2.4Ghz and Doze worked perfect last night with 2-3% drain 8 hours. When I was connected to 5Ghz, I would get 20% drain.
    09-02-2016 08:20 AM
  18. neo905's Avatar
    My option to select 2.4 or 5Ghz was removed on the wifi settings after Nougat. Anyone else notice this?
    09-02-2016 10:02 AM
  19. RHChan84's Avatar
    I have my router to have a 2.4 and a 5 GHz signal with two different names. I disconnected from the 5ghz and "forgot" the password.
    09-02-2016 10:42 AM
  20. Ron Copsetta's Avatar
    I'll check mine tonight see if there's a difference, I have the Netgear nighthawk ac1900
    09-02-2016 11:27 AM
  21. RHChan84's Avatar
    Should be an option to disable 5Ghz just to see if it helps. I have the Asus AC-66U which is equivalent to an AC1750 chipset. I rarely use 5Ghz since it does allow up 300mbps and 2.4 utilizes up to 80mbps. So it's a downside but it's not a big deal to me. My laptop will use the 5ghz and phones will use 2.4
    09-02-2016 02:07 PM
  22. tonyr6's Avatar
    I will never disable 5ghz. I have no choice in my area. 2.4ghz is overcrowd with over 70 AP networks that it is basically unusable and I rather use my T-Mobile LTE network then. Still being able to disable 2.4ghz on Android was good as it helped a bit with the battery which now you can't do thanks to Google what I have to root for to do that now. Really.
    09-02-2016 05:03 PM
  23. RHChan84's Avatar
    That makes sense. I can use either and not have an issue. I did but once I changed to a manual channel selection, I haven't had an issue.
    I used an app called wifi analyzer to choose the least populated channel and I'm all set.
    09-02-2016 05:06 PM
  24. GSDer's Avatar
    Gsam can't track battery usage by individual app. Out can only give me an aggregate figure.
    There's an ADB command that you can run which will grant the necessary permission. It may be documented earlier in this thread; it's certainly in a similar topic and of course you can Google it.
    PhiPsi32 likes this.
    09-02-2016 05:35 PM
  25. Jorgis's Avatar
    I too have higher than usual android os usage. Doze seems to be working fine for me though. Just don't know what can be keeping my phone awake. I do not use any social apps. Wondering if the 5ghz wifi is a cause. Will test that out.
    09-05-2016 01:51 PM
30 12
  1. i got a android system update the morning it was released but
    By Goosinurwife in forum Android 7.0 Nougat
    Last Post: 09-06-2016, 01:21 PM
  2. Conditioning Battery? Is it a myth?
    By Gsxr151 in forum Samsung Galaxy Note 7
    Last Post: 08-24-2016, 10:23 PM
  3. Factory reset with no restore is manadory for 7.0 Nougat.
    By tonyr6 in forum Android 7.0 Nougat
    Last Post: 08-24-2016, 04:30 PM
  4. How do I remove the Android 7.0 update from my phone.
    Last Post: 08-24-2016, 04:43 AM
  5. heating issue
    Last Post: 08-24-2016, 02:33 AM
