1. Nanope's Avatar
    Anyone else since dp5 to 7 release getting really bad connection?: I really wanted to keep this phone another year to keep my bill down. But this is getting really out of hand.
    09-03-2016 04:06 PM
  2. B. Diddy's Avatar
    Moved to the 6P forum (was originally in the 6P Accessories forum).
    09-04-2016 02:56 AM
  3. GSDer's Avatar
    Cellular signal or WiFi?
    Have you tried wiping the system cache in Recovery mode? What about a Factory Reset?
    09-04-2016 10:14 PM
  4. JeBe4's Avatar
    I'm noticing issues on WiFi, If I turn off WiFi apps and stuff work again. Didn't have this data issue until "update" all my other devices work just fine
    09-05-2016 06:22 AM
  5. GSDer's Avatar
    Do you have the same complaint as the OP (problem after update from DP5 to release build)?
    09-05-2016 10:06 AM
  6. Nanope's Avatar
    I keep forgetting about this post until I get home. And well the single on this phone is so bad I can't even log onto my account. But this pic shows what I have dealt with for almost a year. And the reason I might be forced to preorder the iPhone tonight. We all have the same carrier and other phones work perfect. Notr7,n6,s7e,ip6+note5,moto13. So
    09-08-2016 08:33 PM
  7. Nanope's Avatar
    Pic didn't seem to post. But it's just a screen shot of the d/c screen in hearthstone.
    09-08-2016 08:36 PM
  8. GSDer's Avatar
    the SIGNAL on this phone is so bad I can't even log onto my account
    You're referring to cellular signal?
    Have you used an app like SignalCheck Pro https://play.google.com/store/apps/d...ne.signalcheck (there's also a free version) to track the actual signal levels? You could have the other Android users do a comparison to your device at the same location. Perhaps there's just something wrong with that particular device.
    09-08-2016 09:44 PM
  9. Nanope's Avatar
    Ya Cellular. And yes I'm always around100-112. But it's not just at my place it's everywhere. And most the time I have to toggle airplane mode on and off to give it a kick start. Just thought I would check on here before I order a iPhone. Sucks because I really like this phone and the screen ;( but 16 is a iPhone year for me I guess.
    09-08-2016 11:20 PM
  1. Replies: 10
    Last Post: 09-03-2016, 06:41 PM
  2. Replies: 2
    Last Post: 09-03-2016, 06:33 PM
  3. Replies: 11
    Last Post: 09-03-2016, 05:35 PM
  4. USB computer connection option not available on andriod phone
    Last Post: 09-03-2016, 01:46 PM
