1. Tombotje's Avatar
    Since a few weeks ago my nexus 6p has stopped Playing sound via speaker or via aux( only sound via Bluetooth works). Also camera isnt working at all and everytime I answer a call my Phone just crashes after a few seconds. I've tried deleten my cache, running my Phone in save mode, deleting apps and also a full restore to factory settings. Nothing seems to be working. And on top of all of the above my 6p is still not getting the latest Android update to nougat even though I applied for Android bèta. Help is much appreciated.
    09-28-2016 06:47 AM
  2. B. Diddy's Avatar
    If this is happening in Safe Mode, then there's either a problem with the firmware or the hardware. Try manually reinstalling or updating the firmware: How to manually update your Nexus | Android Central. Find the firmware here: https://developers.google.com/android/nexus/images
    If that doesn't help, then contact Google or Huawei for warranty repair.
    09-28-2016 10:36 AM
  3. sudulgidy's Avatar
    I have the same issue. I don't get any sound when watching a movie via Google Play, same with listening to Play music. I still get notifications from text apps.
    10-07-2016 08:17 AM
  4. GSDer's Avatar
    And you have the Media volume turned up (as opposed to the Notification volume)?
    10-08-2016 06:38 PM
  5. Ricky Wang2's Avatar
    And you have the Media volume turned up (as opposed to the Notification volume)?https://uploads.tapatalk-cdn.com/2016...4a621a28df.jpg
    Same problem.....anyone got a fix yet?
    04-25-2018 07:12 PM
  6. GSDer's Avatar
    Same problem.
    You have the same problem where neither the speakers nor AUX jack produce any sound but Bluetooth works fine?
    And you've tried the same things (Safe mode; Factory Reset and setup as new)?
    04-25-2018 09:55 PM
  1. T-Mobile and Google Voice
    By miller7796 in forum General Carrier Discussion
    Last Post: 10-11-2016, 12:17 AM
  2. Replies: 1
    Last Post: 09-30-2016, 05:12 AM
  3. Replies: 1
    Last Post: 09-30-2016, 05:10 AM
  4. VZW September update killing my battery
    By mundo472 in forum Samsung Galaxy S7 edge
    Last Post: 09-29-2016, 03:59 PM
  5. How can I turn on my s7 edge with a broken power button
    Last Post: 09-28-2016, 06:54 AM
