1. PaulQ's Avatar
    I have not rooted or ROM'd a phone in a long time. I haven't paid attention to anything about rooting the 6P because I thought I wouldn't be doing it ever again. Now I'm seeing some Xposed modules I might want to try and I'm curious about activating Assistant on the 6P (who knows how long Google will let that remain).
    Are there any side effects to rooting the 6P? Will I still get OTA updates? Will I still be able to manually install OTA's? Will my warranty go void? Nexus protect? Is it easy to "unroot" the phone? Anything bad?
    Thanks!
    10-14-2016 01:51 AM
  2. Tim1954's Avatar
    Technically it can all be undone, but unless you follow instructions precisely you could brick the device very easily. You don't get security updates ave you are vulnerable to malware. In any case, so your research very carefully and be sure you have the exact same model etc when you start! Backing up is a nobrainer of course.... Good luck
    10-14-2016 04:26 AM
  3. VAVA Mk2's Avatar
    While true, it is very hard to permanently brick a Nexus
    10-17-2016 10:01 PM
  4. PaulQ's Avatar
    I am comfortable with actually rooting the phone. It has to be easier than the other phones I have done it to.
    So - the big drawback is that you don't get monthly security updates? Could I just install the OTAs manually?
    10-18-2016 02:30 AM
  5. bjrosen's Avatar
    You can always install the images directly, if you root that's what you will have to do because you won't get OTAs. The other thing you will lose is Android Pay but that's no big deal. If you do it let us know if Assistant is worth the hassle of rooting. I haven't rooted my phone since the Galaxy Nexus where it was practically required due to the terrible support that the Verizon GN got. Standard Android plus NovaLauncher has been good enough on both the 5 and the 6P however Assistant is the first thing that might be worth rooting to get.
    10-18-2016 09:35 AM
  6. PaulQ's Avatar
    I think I am going to hold off. I do use Android Pay periodically but I could live without it. I don't want to get into it now.
    10-18-2016 01:44 PM
  7. JimSmith94's Avatar
    FYI, apparently SafetyNet was updated again yesterday. Now Android Pay won't work even on a fully stock and unrooted phone if the bootloader is unlocked.
    10-19-2016 10:03 AM
  1. Auto rotate only works on you tube
    By Chris Robinson7 in forum Sony Xperia E3
    Last Post: 10-22-2016, 09:25 AM
  2. yu you're ka root
    By vipin yadav7 in forum Ask a Question
    Last Post: 10-14-2016, 05:23 AM
  3. Replies: 1
    Last Post: 10-14-2016, 01:56 AM
  4. How do i get rid of the white circle on my phone
    Last Post: 10-14-2016, 01:19 AM
  5. Replies: 0
    Last Post: 10-14-2016, 01:07 AM
