1. PaulQ's Avatar
    I really hate to be "that guy" with the battery drain issue but this is the first time I have been hit by a significant one for no apparent reason. I am pretty sure it started after the 1/5 update. I'm not 100% sure but if any of you are having the same problem, then that's it.
    It's bad. Like it's down to 20% by mid-day when it used to be at 50% or above for what would be my typical usage pattern. I am having to plug in during the day and never had to before.
    When I check the battery usage, it's typically "screen" (duh) and android system stuff. No apps appear above 2%, most 1%.
    I know these things are hard to nail down. I think I just want to know is anyone else experiencing this around this update?
    My only other change in life is I've had to move to a rental house while my home is being worked on. It's in central Phoenix, maybe 10 miles from my home. Could some sort of tower issue be causing this? I'm in the middle of a major city.
    Thanks for your insight!
    01-08-2017 11:06 PM
  2. B. Diddy's Avatar
    What's your cell signal strength like? Go to Settings>Battery and tap the graph to bring up the fullscreen graph that has the cell signal strength.
    Also, have you done a cache partition wipe yet?
    01-09-2017 12:01 AM
  3. PaulQ's Avatar
    I forgot about that info. I just checked. Keep in mind I just took it off the charger about 90 minutes ago. Here at the rental house, it shows a dark green block.... a couple lighter green.... and the one on the end is yellow. It isn't very long. I'll be checking this tomorrow. I'll actually be at both locations tomorrow.
    No, I am going to do that right now!
    B. Diddy likes this.
    01-09-2017 12:13 AM
  4. PookiePrancer's Avatar
    Mine's doing the same thing. I've dropped 20% in an hour. Biggest culprit? Kernel.
    01-10-2017 06:34 PM
  5. PaulQ's Avatar
    Mine is still draining rapidly. If it's the kernel then I guess we are screwed until the next update (maybe) fixes it.
    01-10-2017 08:22 PM
  1. I am unable to change my security setting from pin to none
    By Prakhar verma in forum Legacy Android & Other OS's
    Last Post: 01-14-2017, 08:41 AM
  2. Replies: 4
    Last Post: 01-14-2017, 12:39 AM
  3. What do i use to dowload music to Googl Pixel.
    Last Post: 01-09-2017, 02:14 AM
  4. Replies: 1
    Last Post: 01-08-2017, 11:02 PM
  5. Can't get steps to track on Dicks move app
    Last Post: 01-08-2017, 10:06 PM
