1. Zer081's Avatar
    Hi,
    I have recently had the Android 8 update applied OTA to my Nexus 6P and now for the life of me, I can't seem to get the notification LED to work.
    I have gone into Settings -> Apps & Notifications -> Notifications and enabled Blink light, but still nothing seems to show on the LED when the screen is off.
    I did briefly install Lightflow to check that the LED is still infact working (it is), but soon uninstalled it as it seemed to be a right pain to get it configured the way I wanted (e.g. for some reason, when Lightflow was installed, I seemed to stop getting any notifications at all!)
    It seems too much of a pain to have to install 3rd part software for something that should work as standard.
    Any help much appreciated.
    09-18-2017 03:54 AM
  2. GSDer's Avatar
    I had Light Flow installed prior to the 8.0 OTA. It stopped working immediately after the update but I was getting a blue LED notification whenever I got TMs. I finally found the 'Blink light' setting that you mentioned (they just had to move stuff around, didn't they?) and after enabling it Light Flow started operating like before.
    I did look around in the Light Flow settings but didn't fiddle with anything.
    09-18-2017 07:39 PM
  1. Moving from Apple to Android
    By Chri592 in forum Buyers Guides
    Last Post: 10-02-2017, 01:26 PM
  2. Replies: 1
    Last Post: 09-17-2017, 10:10 PM
  3. Replies: 1
    Last Post: 09-17-2017, 10:06 PM
  4. Problem with updating Nextbit robin from Android 7.0 to Android 7.1.1
    By pmuntima in forum General Help and How To
    Last Post: 09-17-2017, 09:36 PM
  5. Does the Samsung S8 Reminder app have an alarm notification?
    By BobbyShazam in forum Samsung Galaxy S8 & S8+
    Last Post: 09-17-2017, 06:13 PM
