1. dty06's Avatar
    So like everyone else, I've been experiencing some battery drain issues. Fortunately I've avoided the 30% shutdown issue as well as the bootloop issues, but the battery was draining from 100% to under 70% in about 20 minutes of use (bluetooth + location off, brightness 30%). I didn't want to switch as I'm waiting for the Pixel 2 which is only a few weeks from launch, but I also can't live with a phone that has to be tethered to a charger every couple hours. So I had my battery replaced. I went to a shop, had them order the part, came back in a week later and had them do the swap. It took about 20 minutes and that was that. So how's the battery life now? Well, with over an hour SoT, the battery level is at 82% - exactly as good as when I bought it.
    Battery replacement: success.
    09-20-2017 12:09 PM
  2. rbell2915's Avatar
    Is the shop you when to a national chain? There's a ubreakifix near my mom's house I've been thinking of taking my 6P to when I come to America again.
    09-20-2017 06:19 PM
  3. dty06's Avatar
    This was a local place. If anyone is near Philadelphia I can make a recommendation. They gave me a good deal on it, too. $60 including the part.
    09-21-2017 06:51 AM
  1. Warning!! Do not let your battery die!
    By AZwldcats in forum Samsung Galaxy Note 8
    Last Post: 11-14-2019, 10:35 PM
  2. Android OS/Android System using battery on standby
    By urafiq92 in forum Samsung Galaxy Note 8
    Last Post: 10-31-2017, 07:05 AM
  3. Recommendations for Phone App Replacements?
    By BoogieNY in forum Google Pixel & Pixel XL
    Last Post: 09-23-2017, 08:12 AM
  4. Has anyone successfully rooted the lg k3?
    By Anthony vaccaro in forum Ask a Question
    Last Post: 09-21-2017, 02:19 PM
  5. New phone, need to replace Contacts file - can't root
    By tahx in forum Legacy Android & Other OS's
    Last Post: 09-20-2017, 01:07 AM
