    So far, this issue occurs on my Nexus 6P and my buddy's OnePlus One on my home's wifi. My laptop and desktop have no wifi issues. Once every couple of minutes, the wifi would disconnect, phone would switch to data, then wifi would reconnect. Both the phone carrier and home internet is with Rogers. I've tried restarting both the router and phone. Selected "Forget Network" on the phone. Cleared phone's cache. Called Rogers to check on the home internet, and the rep said there are no issues with the modem.
    10-27-2017 03:22 PM
  2. GSDer's Avatar
    Do those same phones experience that issue when using other Wi-Fi sources?
    Assuming that they don't there's something strange about the modem/router. You could try connecting to the 5GHz band (if the router offers that), or just change the security type (temporarily) and see if that makes a difference.
    10-27-2017 09:40 PM
  3. thilly09's Avatar
    It's only the home router this is happening at. The wifi at work is fine.
    10-28-2017 11:47 AM
  1. P9 wifi range issue....
    By Android Central Question in forum Huawei P9 & P9 Plus
    Last Post: 11-06-2017, 08:13 AM
  2. Nexus 5x fingerprint issue
    By Android Central Question in forum Nexus 5X
    Last Post: 10-31-2017, 09:39 AM
  3. Wifi Triangles
    Last Post: 10-28-2017, 11:56 AM
  4. Nexus 5x fingerprint issue
    Last Post: 10-27-2017, 07:09 AM
  5. P9 wifi range issue....
    Last Post: 10-27-2017, 04:25 AM
