    I have a Nexus 6P that I have owned since 2015. The Android software does not execute but instead shows an error showing "No Command". Can you please advise how I should fix this?
    12-26-2018 03:34 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! The firmware might have become corrupt, or the motherboard might be failing. Are you able to boot into Recovery Mode and do a factory reset from there? https://www.hardreset.info/devices/h.../first-method/
    12-27-2018 06:43 AM
  1. Why can't I install PUBG Mobile on my LG V30?
    By Android Central Question in forum LG V30
    Last Post: 02-23-2019, 05:53 AM
  2. Is there an upgrade for Samsung GS5 v6.0.1?
    By Android Central Question in forum Samsung Galaxy S5
    Last Post: 12-27-2018, 06:45 AM
  3. How can I connect a Plugable, (Usb B to Ethernet adapter) to my Samsung Note 5?
    Last Post: 12-26-2018, 03:39 PM
  4. Replies: 1
    Last Post: 12-26-2018, 03:08 PM
  5. Why can't I install PUBG Mobile on my LG V30?
    Last Post: 12-26-2018, 01:51 PM
