1. dangerousfen's Avatar
    Immediately after the April Security Patch arrived, I've noticed a significant battery drain compared to previous usage.
    Anyone else noticed this?
    05-08-2020 03:13 PM
  2. B. Diddy's Avatar
    How many charge cycles have you seen this with?
    05-08-2020 04:48 PM
  3. dangerousfen's Avatar
    The 7.1 has been faultless since I purchased it 18 months ago.
    I received the April security patch overnight and installed it first thing Wednesday morning and by the afternoon the battery was down to 45% . It would normally be at that level when I turn in for bed.
    I've tried several restarts to no avail.
    Again today, by the afternoon it was down to about 55% with no usage to speak of.
    I have only carried out two charge cycles since Wednesday.
    05-08-2020 05:06 PM
  4. B. Diddy's Avatar
    Can you show us some battery stats over the span of a charge, from 100% down to about 20-30%? Make sure to tap the Menu button and select Show Full Device Usage so that system processes are shown as well.
    05-08-2020 05:31 PM
  5. dangerousfen's Avatar
    Ok, having never been troubled with battery issues in the past, what's the best app to use?
    05-08-2020 05:57 PM
  6. B. Diddy's Avatar
    Just start with the Settings>Battery screen in the system settings. I'm not sure how the Nokia's system settings are organized, but on a Pixel, I go to Settings>Battery, then tap Menu>Battery Usage, and then Menu>Show Full Device Usage. If there's a particular app or service that's misbehaving, it should show up there pretty clearly.
    05-08-2020 06:05 PM
  7. dangerousfen's Avatar
    Thanks, I'll get back in a while.
    05-08-2020 06:11 PM
  8. dangerousfen's Avatar
    Ok, after the third change cycle things seem to have settled down and now virtually back to normal. See screen shots.
    One thing I did find odd was that directly after the update I was suddenly receiving weather notifications from Google. Never had these prior to the update. I've now turned that feature off.
    Fingers crossed, now hoping all is well. Thanks for your help.
    Battery excessive drain after April Security Patch.-screenshot_20200509-100332.jpgBattery excessive drain after April Security Patch.-screenshot_20200509-123446.jpegBattery excessive drain after April Security Patch.-screenshot_20200509-165213.jpegBattery excessive drain after April Security Patch.-screenshot_20200509-173844.jpeg
    B. Diddy likes this.
    05-09-2020 11:48 AM
  9. TgeekB's Avatar
ID:	320245Click image for larger version.
ID:	320246Click image for larger version.
ID:	320247Click image for larger version.
    It could have just been the update settling in.
    Depending on how extensive an update is it can take a while, and some battery, for apps and services to get themselves back to normal.
    Glad it worked out.
    dangerousfen likes this.
    05-09-2020 12:59 PM
  10. B. Diddy's Avatar
    Yep, I was just about to suggest what TgeekB already said. I'm never quite sure what's involved with an update settling in, but it does seem to be a real phenomenon. In the first charge cycle at least, I would imagine that the process of app optimization is part of the battery drain.
    05-09-2020 01:26 PM
  11. dangerousfen's Avatar
    Thanks again guys.
    05-09-2020 01:37 PM
  12. dangerousfen's Avatar
    Day 4 over and really smokln' now. Couldn't be better.
    05-11-2020 03:01 AM
  1. Unwanted folders, privacy, and Security?
    By Mitul M in forum Ask a Question
    Last Post: 06-16-2020, 11:09 PM
  2. Not Prompted to Log-in Again After Password Change- LG Stylo 4
    By Dqvey in forum General Help and How To
    Last Post: 05-08-2020, 01:35 PM
  3. phone not charging after installing custom rom. what to do?
    By Sriram SR in forum General Help and How To
    Last Post: 05-08-2020, 01:26 PM
  4. phone not charging after installing custom rom. what to do?
    Last Post: 05-08-2020, 08:20 AM
  5. Battery not the size as in specs.
    By JakobM in forum Hardware Hideaway
    Last Post: 05-07-2020, 07:47 PM
