Is there a way to get the battery percentage to display as a stand alone icon in the status bar rather than as a number inside the battery icon?
Whenever I enable the option to show the percentage it shows up inside the battery icon which is harder to see. I thought the default behavior of Pie was to show it as a separate number.
Thanks!
Thanks!
