1. paulgj's Avatar
    Is there a way to get the battery percentage to display as a stand alone icon in the status bar rather than as a number inside the battery icon?
    Whenever I enable the option to show the percentage it shows up inside the battery icon which is harder to see. I thought the default behavior of Pie was to show it as a separate number.
    Thanks!
    06-05-2019 06:38 PM
  2. mustang7757's Avatar
    Thanks!
    Not familiar with Nokia but check in settings of the battery ?
    06-05-2019 09:20 PM
  3. paulgj's Avatar
    Thanks, the only option within the Battery settings just turns on and off the percentage within the battery icon.
    06-05-2019 09:35 PM
  4. mustang7757's Avatar
    I can ask some of my team members see if they can help.
    06-05-2019 09:36 PM
  5. paulgj's Avatar
    that would be great. From what I can gather It seems that options normal behavior on Android Pie is to turn on and off the percentage as a separate icon on the taskbar.
    06-05-2019 09:39 PM
  6. mustang7757's Avatar
    Try go in settings and the search bar type battery percentage see what pops up
    06-05-2019 09:51 PM
  7. mustang7757's Avatar
    I asked some team members looks like Motorola and Nokia follow this way in the battery icon the percentage .
    06-05-2019 10:07 PM
  8. paulgj's Avatar
    hmmmm, interesting. Thank you for checking that out. I figured with the Android One phones it would be completely stock for the most part.
    06-05-2019 10:25 PM
  9. mustang7757's Avatar
    Your welcome, yeah I thought the same , I checked my pixel 3xl and 2xl and the percentage is separate from battery icon .
    06-05-2019 10:28 PM
  10. dangerousfen's Avatar
    This battery percentage issue has been bugging me since I got the phone six months ago. There's no way round the problem I'm afraid.
    06-06-2019 12:31 PM
  11. unclefunbuckets's Avatar
    When you pull down from the top the percentage shows next to the battery I on on my phone.
    06-06-2019 12:56 PM
  12. dangerousfen's Avatar
    Yes it does, but you can't get it to stay there. When it's set to show inside the battery icon, you just can't read it. Stupid idea.
    06-06-2019 03:07 PM
  13. unclefunbuckets's Avatar
    I fully agree!
    06-07-2019 01:02 PM
  14. adonesc76's Avatar
    Thanks!
    On the BlackBerry 10 and Blackberry Android phones you could just swipe up on the home screen and the battery percentage would appear at the top of the screen but would not stay either.
    Look at it this way. At least on the Nokia 7.1 you can still see the percentage inside the battery icon.
    The problem is that without having a notification light if I turn off the phone to charge it, I have no idea when it's full because there is no extra display unless you gently press the power button, only then will you see where you're at in terms of the charge.
    06-12-2019 09:41 PM
  15. paulgj's Avatar
    Regarding keeping an eye on the battery charge level while charging, you can monitor the charge level if you have the ambient display set to always be on during charging.
    adonesc76 likes this.
    06-12-2019 09:52 PM
  16. adonesc76's Avatar
    Thank you for the reply. Even when the phone is off?👍
    06-13-2019 12:23 AM
  17. adonesc76's Avatar
    Thanks!
    I just also noticed that the battery status (percentage) also shows up at the bottom of the locked screen as well...😕
    06-14-2019 09:54 AM
  18. tony bag o donuts's Avatar
    Battery widget reborn or accubattery from the store will accomplish what you want.
    07-10-2019 04:02 PM
  19. unclefunbuckets's Avatar
    Is there any way to remove the Nokia battery icon from the bar? I looked but couldn't find it.
    07-11-2019 01:08 PM
  20. unclefunbuckets's Avatar
    I have my own I like to use. It wasted the space since there are 2 there.
    07-11-2019 01:09 PM
  1. Can't find downloaded pictures in my gallery of Samsung A50
    By Android Central Question in forum Samsung Galaxy A50
    Last Post: 06-06-2019, 01:24 AM
  2. How would I get UID to set up an app on my phone?
    Last Post: 06-06-2019, 12:06 AM
  3. Does the Tizen 4.0.0.4 release in south Asia?(Such as India, Bangladesh, Pakista)
    By Android Central Question in forum Samsung Gear S3
    Last Post: 06-05-2019, 04:36 PM
  4. Does the Tizen 4.0.0.4 release in south Asia?(Such as India, Bangladesh, Pakista)
  5. In M20 after pie update always on display is not available why
    Last Post: 06-05-2019, 04:25 PM
