When I go into messaging and try to send a text to someone, I get 3 red dots, going back and forth. Sort of like it is "working."
But It won't send for about 5 minutes. I tried taking out the SIM and reinserting it. I can send texts....but eventually....not right away.
Also, my phone was plugged in charging DEFINITELY AROUND 85% when I laid down, I woke up from a nap and could not get the phone on. Some red error with white letters below it. It only flashed for 1/1000th of a sec. But, when I took out of the wall, the phone error stayed on. It said 'battery is too low to turn on - charge for awhile before turning on.' Well I charged for 5 min and it was fine.
I can only think that it has something to do with some oddities that I have read about OnePlus regarding wall chargers or cables??
-I was using their dash cable. At some point I was using that cable with a Anker 5000mah external battery, and at another point I was using Anker's 4-port wall adaptor. Really weird since I never get my battery below 85ish. One of those things drained it.
All I want to know is a guess as to which one, and which one I shouldn't do, and that all is fine, it is one of the oddities of OnePlus as I said.
Thank You
Thank You
