1. Varshasuresh17192's Avatar
    Dust gets under op3 edge to edge tempered glass ...Does it happens for all ?
    01-23-2017 03:21 AM
  2. Javier P's Avatar
    Mod note. Thread moved to the OnePlus 3 & 3T forum for more visibility.
    01-23-2017 06:35 AM
  3. mchockeyvette27's Avatar
    I have not seen dust under the screen protector yet, have had it on for a little over a month. I have had dust get in-between other ones, but not the OnePlus protector yet.
    01-23-2017 08:20 AM
  4. speedlever's Avatar
    I don't think the TGSPs adhere completely to the surface of the phone like the soft plastic ones.
    01-23-2017 10:33 AM
  5. mchockeyvette27's Avatar
    The one plus protector does. All other ones I have tried, do not. And I've gotten dust under those.
    01-23-2017 10:53 AM
  6. speedlever's Avatar
    So the TGSP from OP adheres completely to the screen? Good to know. Thanks. Does it work well with cases like the Spigen Rugged Armor?
    01-23-2017 10:56 AM
  7. Kobena's Avatar
    I have the Spigen Rugged Armor and so far it looks fine. I have had it for barely a week though so can't tell you about longevity.
    01-23-2017 11:01 AM
  8. speedlever's Avatar
    Good. If that works well, I may have to come up with some accessories I need to buy to justify getting the OP TGSP.
    01-23-2017 11:09 AM
  9. Bash_Man's Avatar
    Hi there,
    are you refering to the Curved Temp glass from OnePlus? or the regular Temp Glass from OnePlus?
    Thanks
    01-23-2017 02:03 PM
  10. speedlever's Avatar
    I guess I didn't realize there was more than one option!
    01-23-2017 03:13 PM
  11. mchockeyvette27's Avatar
    Hi there,
    Thanks
    I was assuming they're talking about the curved one, since that's really the edge to edge protector that they're referring to. But I could be wrong.
    01-23-2017 06:27 PM
  1. Android Nougat manual update fail due to low storage?
    Last Post: 01-23-2017, 03:22 AM
  2. Replies: 0
    Last Post: 01-23-2017, 03:04 AM
  3. unable to view my photos after transfer to SD card
    Last Post: 01-23-2017, 12:41 AM
  4. Down load saved games to a Nvidia Shield K1 tablet
    Last Post: 01-22-2017, 11:36 PM
  5. How can I get my droid turbo 2 unblocked
    Last Post: 01-22-2017, 10:55 PM
