1. dannyar11's Avatar
    Is anyone having issues with apps that use data? More specifically im having issues getting apps like tunein radio and pokemon go to work. I have full LTE service but the apps will not load up. Upon connecting to wifi they load up immediately. Apps like twitter and facebook do not seem to have any issues refreshing, but for whatever reason these apps fail to load.
    06-27-2017 08:57 AM
  2. digitalbreak's Avatar
    I use TMobile in my OP5 and have had no issues so far. I even use dual SIM and have set one exclusively for data while the other SIM for voice and text.
    I have not tried those specific apps but Google Play Music streaming, browsing web all works fine in LTE.
    06-27-2017 10:26 AM
  3. dannyar11's Avatar
    Thanks for the reply. I also am not having issues on most of my apps but I do see it with a few that I use often. I was already on the fence about keeping the device because for the cost its not giving me what I would get for a few bucks more from a u11. I had a short leash with the OP5 and this problem just seals the deal and ive already requested an RMA to send it back.
    06-27-2017 10:35 AM
  4. krazyatom's Avatar
    @OP
    I think OP5 just released fix for that 4.5.3
    06-27-2017 12:29 PM
  5. dannyar11's Avatar
    @OP
    Downloading now to see if it fixes it
    06-27-2017 01:14 PM
  6. dannyar11's Avatar
    Just finished updating and this did not fix issue. Apps still hang and do not load up.
    krazyatom likes this.
    06-27-2017 01:24 PM
  7. krazyatom's Avatar
    Their update log specifically said that it will fix the issue.
    https://forums.oneplus.net/threads/o...plus-5.556197/
    06-27-2017 01:39 PM
  8. krazyatom's Avatar
    I think you need to update the apn settings.
    ****Known issues and fixes:
    Unable to use WeChat and PokemonGo under US T-Mobile network
    Please manually reconfigure your APN settings to:
    Name: T-Mobile US LTE
    APN: fast.t-mobile.com
    Proxy: <Not set>
    Port: <Not set>
    Username: <Not set>
    Password: <Not set>
    Server: <Not set>
    MMSC: http://mms.msg.eng.t-mobile.com/mms/wapenc
    MMS proxy: <Not set>
    MMS port: <Not set>
    MMS protocol: WAP 2.0
    MCC: 310
    MNC: 260
    Authentication type: <Not set>
    APN type: <Not set>
    APN protocol: IPv4/IPv6
    APN roaming protocol: IPv4
    Enable/disable APN: <greyed out unless there are multiple APN's>
    Bearer: Unspecified
    J R Mtz, tube517, ecr80 and 1 others like this.
    06-27-2017 01:44 PM
  9. dannyar11's Avatar
    This fixed my issue. Good to know Oneplus isn't sitting around sucking their thumbs and is fixing issues asap.
    06-27-2017 03:41 PM
  10. J R Mtz's Avatar
    Proxy: <Not set>
    Port: <Not set>
    Username: <Not set>
    Password: <Not set>
    Server: <Not set>
    MMS port: <Not set>
    MCC: 310
    MNC: 260
    APN type: <Not set>
    Bearer: Unspecified
    Thank you! A lot of stuff worked well, but noticed my ecobee app wouldn't detect the network. Wonder what the difference is between the default and this one.
    06-27-2017 06:24 PM
  11. JeBe4's Avatar
    You didn't compare them before changing lol o_O - I think it's IP4 protocol - I'm curious to know the changes from manual and auto
    06-28-2017 04:18 AM
  12. J R Mtz's Avatar
    Yes, I noticed that line item was different, but wonder why that specific item prevents some apps from working properly.
    06-28-2017 07:11 AM
  13. JeBe4's Avatar
    Some tech crap about IP6 vs 4 etc.
    06-29-2017 10:03 AM
  1. Wifi Connection icon
    By Chuckcell in forum Google Pixel & Pixel XL
    Last Post: 06-28-2017, 08:17 AM
  2. Replies: 1
    Last Post: 06-27-2017, 11:22 AM
  3. Why is my wi-fi tecno j7 and Bluetooth not turning on
    Last Post: 06-27-2017, 07:48 AM
  4. Why is Go SMS Pro resending pictures on its own?
    Last Post: 06-27-2017, 07:45 AM
  5. Bluetooth and wifi not turnng on why for infinix
    Last Post: 06-27-2017, 07:14 AM
