1. Ryano89's Avatar
    I keep seeing a notification in my battery setting that says Contacts app has high battery usage. Anyone else seeing this? TMobile version, if that matters.
    12-02-2018 09:00 AM
  2. Lepa79's Avatar
    On T-MOBILE here but no alerts of contacts app draining battery
    12-02-2018 11:36 AM
  3. B. Diddy's Avatar
    Go to Settings>Accounts and select your Google account. Does it show that Contacts is constantly syncing? If so, there might be a corrupt contact that is causing the sync to get stuck.
    12-02-2018 04:55 PM
  4. Ryano89's Avatar
    Thanks for the tip, that wasn't it, but I'll keep an eye on it.
    12-02-2018 05:38 PM
  5. B. Diddy's Avatar
    Also go to Settings>Accounts and see if there are any other accounts besides Google that are also syncing contacts. If there are, and if you don't need them to, turn those contact syncs off.
    12-02-2018 05:53 PM
  6. benjamin19's Avatar
    Mine did that after I used Duo for a video call. Think it was trying to communicate with the contacts app to get everything synced up. Were you using Duo?
    12-03-2018 10:36 PM
  7. Ryano89's Avatar
    No, but I do have it installed. Hmmm
    12-04-2018 06:22 AM
  8. benjamin19's Avatar
    I use duo all the times and i never saw it again. I don't think it's a bug, was just a one time thing first time i used it.
    12-04-2018 06:41 AM
  9. Theot's Avatar
    I haven't seen that yet but I'll keep an eye on it.
    12-05-2018 09:37 AM
  1. Crazy Good 6T Battery Life!!
    By Lepa79 in forum OnePlus 6 & 6T
    Last Post: 12-07-2018, 11:49 AM
  2. email contact calendar help
    By bracque in forum Samsung Galaxy S9 & S9+
    Last Post: 12-02-2018, 04:48 PM
  3. Replies: 2
    Last Post: 12-02-2018, 02:14 PM
  4. Factory reset damage ram or phone ? Or battery
    By everbutter in forum Ask a Question
    Last Post: 12-02-2018, 04:09 AM
  5. Text from a contact who isn't IN my contact list?
    Last Post: 12-01-2018, 06:59 PM
