Save big + get 3 months free! Sign up for ExpressVPN today
  1. sheba510's Avatar
    I am using a unlocked OnePlus 8 Pro on T-mobile. Recently I noticed my ringer was set in vibration mode only. I cannot change it from the drop down or go into settings and change it. The ringer volume slider in settings will not move. The up and down volume buttons only adjust volume for media. I have a ring tone selected in settings, but it does work when I call my phone.
    I have sent a bug report to OnePlus, but am wondering if anyone else is having the same problem. And were you able to fix it.
    08-31-2020 08:26 PM
  2. mustang7757's Avatar
    Have you tried safe mode ?
    08-31-2020 09:06 PM
  3. B. Diddy's Avatar
    Do Not Disturb is turned off, right?
    09-01-2020 11:45 AM
  4. sheba510's Avatar
    No, I have not tried safe mode. Don't know how to use it or turn on that feature.
    09-02-2020 01:29 AM
  5. sheba510's Avatar
    Do Not Disturb is turned off.
    09-02-2020 01:29 AM
  6. B. Diddy's Avatar
    Here's how to turn on Safe Mode: www.verizon.com/support/knowledge-base-231358/. It temporarily disables any 3rd party app you installed to help rule that out as a possible cause.
    09-02-2020 01:37 AM
  7. sheba510's Avatar
    I restarted phone in Safe Mode. Don't know what that was supposed to accomplish. I could not turn on the ringer from Safe Mode.
    09-02-2020 01:46 AM
  8. B. Diddy's Avatar
    What it accomplished was to rule out a 3rd party app causing the problem, since you said the problem persists in Safe Mode. So that means it's a problem with either the firmware or the hardware. Do notifications make sounds? Can the phone play media (like music, or the audio from a video)?
    09-02-2020 01:49 AM
  9. Javier P's Avatar
    Have you checked if the physical alert slider is stuck in Vibrate? Do you see any change if you move it up and down?
    B. Diddy likes this.
    09-02-2020 07:13 AM
  10. Javier P's Avatar
    Also, can you open the quick settings panel, take a screenshot and post it here?
    09-02-2020 07:15 AM
  11. sheba510's Avatar
    As you can see in the picture, the ringer volume slider has the open black circle which cannot be moved. The other volume sliders have the movable blue dots.
    09-09-2020 12:15 AM
  12. Javier P's Avatar
    That's what happens when the physical slider is in the Vibrate position. Try to move it and see if anything changes. Also, the slider can accumulate a lot of dirt, clean in with a toothpick just in case.
    09-09-2020 05:20 AM
  13. msm0511's Avatar
    That was my first thought as well. Has to be the 3 way physical slider.
    Javier P likes this.
    09-09-2020 11:43 AM
  14. sheba510's Avatar
    Thank you Javier P and msm0511. It was the physical slider. I must have accidentally moved it while removing and putting on the case. I didn't even know what that slider did. Now I got my phone ringer back!
    msm0511, Javier P and B. Diddy like this.
    09-09-2020 08:16 PM
  15. Javier P's Avatar
    Haha. Now that you know how it works you'll use it a lot. It's very handy.
    mustang7757 likes this.
    09-09-2020 08:31 PM
  16. mustang7757's Avatar
    I mark this thread solved!
    Great find javi and msm
    msm0511 likes this.
    09-09-2020 08:34 PM
  1. Why can't I Focus closely on my Note 20 Ultra?
    By fee dee cat in forum Samsung Galaxy Note 20 & Note 20 Ultra
    Last Post: 09-02-2020, 12:15 AM
  2. Auto fix shapes on S Note?
    By larry1014 in forum Samsung Galaxy Note 20 & Note 20 Ultra
    Last Post: 08-31-2020, 11:08 PM
  3. Why is my Facebook not on my I phone
    Last Post: 08-31-2020, 07:24 PM
  4. Bell symbol with cross on all contacts
    Last Post: 08-31-2020, 05:18 PM
  5. Image problems with Samsung S9
    Last Post: 08-31-2020, 04:39 PM
