Originally Posted by
IHateMyTreo From the developer of AccuBattery:
"Thank you for your email. For these devices with dual batteries the system is incorrectly reporting only half the charge/discharge current. This means the maximum you will get is half the design capacity so you will need to multiply the mAh estimate by 2 or better yet, change the design capacity so it's half the original value. This means you have to also make the assumption that the two batteries wear down at the same rate but from what we've seen so far this indeed appears to be the case. In the future we will try to automatically identify devices that have this issue and ask users to confirm if this is indeed the situation. We can then automatically do the adjustment for you."
Nice response! Always good to see a dev being so responsive.
