Battery Degrading
IHateMyTreo
187
13
18
I don't have any hard numbers, just a gut feeling that the battery is deteriorating, manifested by shorter daily battery life.
Is there any validity to the thought that warp charging incrementally kills the battery over time?
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
165,594
4,736
113
The Battery Health section is what you want to look at, but wait until after a few charge cycles to get an accurate reading. <90% means the battery is getting pretty old, and <85% generally means the battery is at the end of its useful life.
IHateMyTreo
187
13
18
Lol, I'm at 47% which, if I understand the app, means that my battery is operating at about half of the original "capacity" - consistent with my gut feeling.
I wonder if this can be warrantied since I've only had the phone 8 months.
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
165,594
4,736
113
That doesn't look good. But wait for another couple of full charging cycles to get an accurate read. Use the phone until the battery is down to about 20-30%, then charge up to 100% each time.
IHateMyTreo
187
13
18
To edit that go to bottom tap charging then set your design capacity
I did that upon installing the app. So design capacity is set to 4500. "Estimated capacity" can't be manually changed AFAIK and is reading at 2127. I will follow B.Diddy's advice and run it through some charging cycles and see what happens.
mustang7757
Super Moderator
Moderator
Feb 6, 2017
91,578
6,166
113
IHateMyTreo
187
13
18
Yes I did that. It is set at the factory rating of 4500 mAh. I THINK "battery design capacity" is what your battery is specced at from the factory.
But as I understand things, the real "health" reading is the "estimated capacity" which I believe tells us what the fully charged battery would be "worth" today - and this seems to state that with a full charge my battery operates today at the same level as would a battery of 2127 mAh. Which sucks.
mustang7757
Super Moderator
Moderator
Feb 6, 2017
91,578
6,166
113
Ok then thats bad
Ryano89
1,265
If you have a device like the 8t with 65w charging, then accubattery is incorrect. These charging speeds are achieved by give having 2 small batteries instead of one big one. Accubattery does not take this into account. It's only recognizing 50% of your battery capacity
mustang7757
Super Moderator
Moderator
Feb 6, 2017
91,578
6,166
113
This good to know
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
165,594
4,736
113
Ah, that's interesting! I wonder why the Accubattery devs haven't accounted for that yet?
kirk781
