08-23-2021 12:00 PM
26 12
tools
  1. IHateMyTreo's Avatar
    I don't have any hard numbers, just a gut feeling that the battery is deteriorating, manifested by shorter daily battery life.
    Is there any validity to the thought that warp charging incrementally kills the battery over time?
    08-18-2021 04:16 PM
  2. B. Diddy's Avatar
    Have you checked the battery health using something like AccuBattery?
    08-18-2021 04:18 PM
  3. mustang7757's Avatar
    Yeah i would recommend what b. Diddy mentioned to see battery health
    08-18-2021 08:05 PM
  4. IHateMyTreo's Avatar
    Installed it and trying to understand all the tools! I'm no engineer 😂
    08-19-2021 08:37 AM
  5. B. Diddy's Avatar
    The Battery Health section is what you want to look at, but wait until after a few charge cycles to get an accurate reading. <90% means the battery is getting pretty old, and <85% generally means the battery is at the end of its useful life.
    08-19-2021 11:08 AM
  6. IHateMyTreo's Avatar
    Lol, I'm at 47% which, if I understand the app, means that my battery is operating at about half of the original "capacity" - consistent with my gut feeling.
    I wonder if this can be warrantied since I've only had the phone 8 months.
    08-19-2021 04:46 PM
  7. B. Diddy's Avatar
    Whoa, are you sure you're looking at the Battery Health section? Show us a screenshot.
    08-19-2021 04:53 PM
  8. IHateMyTreo's Avatar
    08-19-2021 05:13 PM
  9. B. Diddy's Avatar
    That doesn't look good. But wait for another couple of full charging cycles to get an accurate read. Use the phone until the battery is down to about 20-30%, then charge up to 100% each time.
    08-19-2021 05:16 PM
  10. mustang7757's Avatar
    2127 isn't your design capacity , edit that closer to 4500
    08-19-2021 05:25 PM
  11. mustang7757's Avatar
    To edit that go to bottom tap charging then set your design capacity
    08-19-2021 05:27 PM
  12. IHateMyTreo's Avatar
    I did that upon installing the app. So design capacity is set to 4500. "Estimated capacity" can't be manually changed AFAIK and is reading at 2127. I will follow B.Diddy's advice and run it through some charging cycles and see what happens.
    08-19-2021 05:38 PM
  13. mustang7757's Avatar
    Yes you can set it Battery Degrading-screenshot_20210819-183916_accubattery.jpg
    08-19-2021 05:41 PM
  14. IHateMyTreo's Avatar
    Yes I did that. It is set at the factory rating of 4500 mAh. I THINK "battery design capacity" is what your battery is specced at from the factory.
    But as I understand things, the real "health" reading is the "estimated capacity" which I believe tells us what the fully charged battery would be "worth" today - and this seems to state that with a full charge my battery operates today at the same level as would a battery of 2127 mAh. Which sucks.
    08-19-2021 05:47 PM
  15. mustang7757's Avatar
    Ok then thats bad
    08-19-2021 05:51 PM
  16. mustang7757's Avatar
    Give it few more charge cycles but not looking good
    08-19-2021 05:54 PM
  17. IHateMyTreo's Avatar
    Thanks and will report back in a few days.
    mustang7757 likes this.
    08-19-2021 05:56 PM
  18. Ryano89's Avatar
    If you have a device like the 8t with 65w charging, then accubattery is incorrect. These charging speeds are achieved by give having 2 small batteries instead of one big one. Accubattery does not take this into account. It's only recognizing 50% of your battery capacity
    08-20-2021 03:15 PM
  19. mustang7757's Avatar
    This good to know
    J Dubbs likes this.
    08-20-2021 03:18 PM
  20. B. Diddy's Avatar
    Ah, that's interesting! I wonder why the Accubattery devs haven't accounted for that yet?
    J Dubbs likes this.
    08-20-2021 03:47 PM
  21. IHateMyTreo's Avatar
    Very good to know. That explains why my health readings are about half of the original specs.
    08-21-2021 08:25 PM
  22. Ryano89's Avatar
    I'm not sure honestly. It's not a new concept, you'd think they would have fixed it by now
    B. Diddy likes this.
    08-22-2021 09:24 AM
  23. IHateMyTreo's Avatar
    I sent the AccuBattery devs that very question.
    B. Diddy and Ryano89 like this.
    08-22-2021 09:43 AM
  24. IHateMyTreo's Avatar
    From the developer of AccuBattery:
    "Thank you for your email. For these devices with dual batteries the system is incorrectly reporting only half the charge/discharge current. This means the maximum you will get is half the design capacity so you will need to multiply the mAh estimate by 2 or better yet, change the design capacity so it's half the original value. This means you have to also make the assumption that the two batteries wear down at the same rate but from what we've seen so far this indeed appears to be the case. In the future we will try to automatically identify devices that have this issue and ask users to confirm if this is indeed the situation. We can then automatically do the adjustment for you."
    B. Diddy and Javier P like this.
    08-23-2021 11:10 AM
  25. mustang7757's Avatar
    Funny i got a update today for AccubatteryBattery Degrading-screenshot_20210823-122025_google-20play-20store.jpg
    08-23-2021 11:21 AM
26 12
  1. Battery draining so fast then stop at 4%
    Last Post: 08-24-2021, 07:04 AM
  2. S21 Ultra - Why do the last 5% of my battery drains so fast?
    Last Post: 08-17-2021, 12:19 PM
  3. My samsung galaxy M20 is stuck in odin mode but it ran out of battery
    Last Post: 08-17-2021, 04:42 AM
  4. [Solved] Mysterious Battery life Issues, NOT a bad battery.
    By DoctorWizard in forum General Help and How To
    Last Post: 08-09-2021, 09:51 AM
  5. Battery suddenly down from 50 to 0 in my Motorola E4?
    Last Post: 08-08-2021, 11:51 PM
