    Recently upgraded my OnePlus 8 Pro to android 12, however ever since the upgrade my the phone is only able to charge when plugged into my PC.
    When plugged into my wall adaptor, the device appears as though it is charging, although the charge percentage never goes up, it also does not go down, so some power must be reaching the phone.
    I have tried multiple adapters/cables and they all have the same issue. I am also able to charge other devices using these adapters/cables.
    Does anyone have any suggestions for a fix?
    Any help/advice much appreciated.
    05-03-2022 06:56 AM
  2. mustang7757's Avatar
    Did you ever Root your device or change anything in Developer settings? Make sure your phones charger port is clean from lint or other things.
    I'll leave a Link to register so you can communicate here, As a guest account you can only post questions but can't reply
    https://forums.androidcentral.com/sh...d.php?t=409154
    05-03-2022 10:22 AM
  3. B. Diddy's Avatar
    Welcome to Android Central! Does this also happen in Safe Mode? https://www.androidsettings.net/onep...pro-safe-mode/
    05-05-2022 11:40 PM
  1. A volume icon pops up on my phone screen after like every 15 seconds
    Last Post: 05-05-2022, 11:46 PM
  2. I have two android services consuming a lot of data monthly
    Last Post: 05-05-2022, 05:13 PM
  3. Unrecognized notification on my deceased Father's Android
    By questions_i_have64 in forum Android Apps
    Last Post: 05-02-2022, 09:04 PM
  4. Green Light on Screen After Repair
    By ca_jordan in forum Google Pixel 6 & Pixel 6 Pro
    Last Post: 05-02-2022, 08:57 PM
