Battery Calibration Issue
Freelance1040
5
Hey,
Has anybody had a issue with the battery calibration on the 1+1? My battery stays at 100 percent for a couple of hours and then will die when the battery is around 25 percent. I don't think that there is a battery drain, it is just inaccurate. Anybody have a solution?
Thanks
mayankbaba
i m also having same issues with my OPO.. have you find any solution regardis dis den pls lemme know so that i can also perform d same..
taft
Active member
Oct 28, 2011
38
3
You can try manually wiping the battery stats. I don't have my OPO yet, but I would imagine you'll find this option in your custom recovery if you're rooted.
Goliwog
11
I had the same problem before. I think what I did was to let it discharge completely then leave it for a couple of minutes and recharge it.
When recharging, it's important to use the original cable and connect directly to a wall socket. Do not charge it via your PC USB.
taft
Active member
Oct 28, 2011
38
3
Aside from being slower, how is charging through a computer any different?
akbarramadhani12
