1. AC Question's Avatar
    I have a Oneplus One, my previous battery got damaged and I had to replace it. After replacing it, the phone boots while connected to power, but the battery meter is stuck at 0%, the phone turns off immediately after disconnecting it.
    Is there something I could have done wrong?
    Do you know how to fix it?
    05-18-2015 05:06 PM
  2. Nicholas Audy's Avatar
    Are you using the original battery and charger? Cuz if it's not,maybe that's the problem
    05-23-2015 06:35 AM
  3. Dubstepgamer60's Avatar
    be sure that u r using the original battery and charger and check the thing which connects the phone with the battery .. it maybe also a problem in the place in which the charger is connected to the phone ..better to send it to someone to repair it
    Posted via Android Central App from Samsung Galaxy Note II
    05-23-2015 07:57 AM
  4. gpo1956's Avatar
    I constaly have trouble with my factory charger and cable. All others I have tried work great, but the factory charger cosntantly stops charging at 40-50%.
    05-23-2015 10:11 AM
  5. Frank Ross's Avatar
    Hi fellow OPO's, I'm on my second one because it would not charge. Well I started using android chargers from other phone and my H.P. tablet. Everything worked, so I plug in the opo cable and powered down for the night. To my surprise it had lost part of the charge. I recently discovered that the opo cable should have the flat side to the plus on the part that goes in the 120 v. outlet. All in all I'm satisfied.
    05-30-2015 01:51 PM
  1. battery Life
    By dentalexel in forum LG Watch Urbane
    Last Post: 05-15-2016, 05:03 PM
  2. Why am I not able to download Mortal Kombat X?
    By AC Question in forum Android Games
    Last Post: 05-22-2015, 05:47 PM
  3. Install only play store - Not gapps.
    By john808 in forum General Help and How To
    Last Post: 05-20-2015, 04:20 PM
  4. Galaxy S6 can't download Play Store Apps
    Last Post: 05-18-2015, 04:52 PM
  5. Media server battery drain
    By bsannes in forum LG G3
    Last Post: 05-18-2015, 03:24 PM
