theboyshort
No I don't have ZV9. And I use the Default Clockworkmod Recovery.
Sent from my VM670 using Android Central Forums
Flash drews touch recovery, do not use cwm! And if you're still having problems you might wanna do the update, but only do the update with bobzs recovery or you'll brick your phone
Cannibal Open Touch won't brick on flashing radios (I tested it personally) but it also doesn't actually flash the radio image. Are you saying BobZ's recovery ACTUALLY flashes radios?
Oh by the way nyan cat works on quattrimus lol
Got this the other night and I'd agree with reaper420 but when I go onto settings I got these odd lines going across looked like very light bars translucent but visable I should've taken a snapshot but didn't my bad ill reflash later on and send a update
Turn on surface dithering in performance settings
OP updated with latest rom!!!
