09-23-2012 07:30 PM
136 1234 ...
tools
  1. joerivera17's Avatar
    it awesome, but how do i remove the button status bar
    07-16-2012 09:38 PM
  2. Nate456's Avatar
    I'm helping the Op with that
    Edit: nvm
    joerivera17 likes this.
    07-16-2012 09:46 PM
  3. TauSigmaNova's Avatar
    Guys, good news!
    Google Now is loaded and now works with this ROM!
    YAY!
    @Nate, I'll PM them to you as soon as they upload.
    Nate456, O13, topdawg661 and 2 others like this.
    07-17-2012 01:04 AM
  4. jonny5449's Avatar
    awesome
    Looking for good cm9 or cm7 themes??? visit this site for good themes. http://forum.digitalhouseoftreats.com/
    07-17-2012 03:14 AM
  5. jonny5449's Avatar
    porting this to s in exactly 11 hours
    07-17-2012 03:14 AM
  6. TauSigmaNova's Avatar
    Enjoy, just make sure to update it after I update it :P
    07-17-2012 03:31 AM
  7. jetfactor's Avatar
    all of ya'll are gonna give me flashfever.
    TauSigmaNova likes this.
    07-17-2012 04:36 AM
  8. TauSigmaNova's Avatar
    That's not a /bad/ thing.
    Guys, I might even have VanillaBean_0.06a and VanillaBean_0.06c (AOKP and CM9) done today! (Im currently on GMT +3 on vacation) for the testers or even for public release! Yay!
    E: Fixed Nav bar!
    07-17-2012 04:48 AM
  9. YoshinJaa's Avatar
    Thanks for the JB love, about to flash your current build right now So the Nav bar is fixed in 0.05?
    +1 to AOKP as well
    07-17-2012 09:22 AM
  10. TauSigmaNova's Avatar
    +1 to AOKP as well
    0.05 Was the initial. Hold out for an hour while I'm uploading build6 CM9. In about 2-3 hours I'll have AOKP build 6 (1st AOKP build but just for naming reasons) (hopefully) up and running.
    YoshinJaa likes this.
    07-17-2012 09:49 AM
  11. TauSigmaNova's Avatar
    CyanogenMod Update [Build 6] is ready along with the new GApps package and both are up for download in the Original Post!
    inceyet likes this.
    07-17-2012 10:39 AM
  12. JadenBrown30's Avatar
    So this is basically a heavily themed Quattrimus? (:
    07-17-2012 10:51 AM
  13. TauSigmaNova's Avatar
    Heavily themed with some Jellybean applications/features like Google Now and a few performance tweaks.
    07-17-2012 11:04 AM
  14. JadenBrown30's Avatar
    Sounds amazing! Downloading now
    07-17-2012 11:06 AM
  15. clodfelterac's Avatar
    from op:
    "I ended up with this- a half way attempt to get CM9/AOKP to look and function a bit like Jellybean! Welcome to Vanillabean! (Vanillabean= A mixture of Ice Cream [Ice Cream Sandwich with Vanilla Ice Cream] and Jellybeans!)"
    "Using Quattrimus CM9 Nightly 7/16 and AOKP Nightly 7/15 for Update 6!"
    07-17-2012 11:07 AM
  16. TauSigmaNova's Avatar
    Thanks for the support guys.
    If there is ANY:
    • Bugs
    • Things you'd like added
    • Feedback
    • Bad things about this ROM
    • Good things about this ROM
    • Love
    • Hate
    • Improvements from the last build
    • Quirks
    • Or any such things
    please, PLEASE put a post in the thread with it and I will try to fix it!
    Also, PLEASE tell me how Google Now is working?
    07-17-2012 11:11 AM
  17. JadenBrown30's Avatar
    If there is ANY:
    • Bugs
    • Feedback
    • Love
    • Hate
    • Quirks
    Gonna flash now, I'll let you know.
    07-17-2012 11:23 AM
  18. TauSigmaNova's Avatar
    thanks
    07-17-2012 11:26 AM
  19. JadenBrown30's Avatar
    thanks
    So far:
    *I found two identical Camera APK's lol
    *Google Now seems to force close every so often
    07-17-2012 12:12 PM
  20. clodfelterac's Avatar
    also two google search bar.apks in system/apps... build.prop could use some editing...
    07-17-2012 12:19 PM
  21. TauSigmaNova's Avatar
    @Jaden I noticed that. I think it's related to the Gallery. Either Gallery2.apk or Gallery4.apk. Feel free to test it out.
    @Clod
    Also, for Google Now, It seems that I need all 3 of these- GoogleQuickSearchBox, QuickSearchBox, and Velvet to run Google Now. Removing any one of these seems to make Google Now not show up. Weird, right? Feel free to do any build editing too if you want :P Send it to me also and I'll incorporate it into Build 7 or anyone who wants can dl it and place it :P
    E: I think Google Now FCs because it's ported from JB. That and it's only meant for AOSP ROMs, not CM9 ROMs though It appears to work.
    Badboytoast likes this.
    07-17-2012 02:52 PM
  22. clodfelterac's Avatar
    can do... mmmmmkay... ;-)
    07-17-2012 02:57 PM
  23. JadenBrown30's Avatar
    Only one of the camera apps seems to work
    07-17-2012 09:24 PM
  24. papatherapa's Avatar
    Gallery force closes when I try to look at pictures.
    07-18-2012 01:50 AM
  25. colossus3874's Avatar
    Google Now didn't work for me. Force closes every time I try. Looks like a useful tool though!
    07-18-2012 03:06 AM
136 1234 ...
