08-01-2012 09:56 PM
140 12345 ...
tools
  1. BlairFam07's Avatar
    Could you please help me with the other method as I have tried both methods over and over. The same outcome every time. I really appreciate it.
    07-25-2012 12:54 AM
  2. andrewnelson23's Avatar
    okay. if you have facebook you can add me. the chat on there is much quicker and easier. http://www.facebook.com/andrew.c.nelson23
    if not, then we can use personal messaging on here. just click my name and send a message. that's pretty slow though so the fb is the best option.
    BlairFam07 likes this.
    07-25-2012 12:57 AM
  3. sammyz's Avatar
    Did you fix the issues?
    I wont be able to help anyone, working....
    Sent from my Optimus M
    07-25-2012 08:23 AM
  4. BlairFam07's Avatar
    Hey Sammy. It is still not working. I tried what is the 2nd post but with the S's os. here--> [http://forums.androidcentral.com/opt...firmware.html] It however did not work. It doesn't matter if I use the ZV5cab or the LS670ZVD.cab neither one will take. I have done this all night as I was informed it could take a lot of times to get it to work? Also Andrew was saying since its in the CWM-based Recovery that I should use the adb to put files on phone and install but this doesn't help. The Recovery menu will install and zip successfully but it still never boots out of the Recovery menu.
    Thank you
    07-25-2012 09:44 AM
  5. sammyz's Avatar
    Use the cab from the second post, it is a different cab and use only LGNPST with it.
    07-25-2012 10:06 AM
  6. andrewnelson23's Avatar
    I pm'd you with very precise instructions on how to adb push a rom to your phone and then install it. follow my directions to a T, and it should work.
    07-25-2012 10:07 AM
  7. BlairFam07's Avatar
    Thank you both. Sry andrew i didnt see my PM this morning.
    07-25-2012 10:26 AM
  8. BlairFam07's Avatar
    Thank you Andrew for the guidance. Just so everyone knows it was the cwm-based recovery I was running couldn't stop the recovery boot look so. after installing the cannibal touch recovery ZIP file rebooted and installed ROM and gapps and advanced menu fix recovery boot loop. Now I got flashed by lloyd and I am back going! thank you to sammyz
    sammyz likes this.
    07-25-2012 04:07 PM
  9. Nate456's Avatar
    You should put this on VMRoms Sammy.
    Sent from my shole using Tapatalk 2
    sammyz likes this.
    07-25-2012 04:44 PM
  10. sellers86's Avatar
    Ubuntu ,Debian, Redhat, or Mint?
    ubuntu, its much easier to build on. all of my personal computers have linux on it. two are default linux, one is dual booted with windows seven.
    sammyz likes this.
    07-25-2012 06:21 PM
  11. sammyz's Avatar
    Tomorrow.
    07-25-2012 11:13 PM
  12. asadullah's Avatar
    I've got working fastboot
    sammyz likes this.
    07-26-2012 05:46 PM
  13. sammyz's Avatar
    Where?
    How?
    When?
    ZV5???
    ZV9?????
    07-26-2012 06:52 PM
  14. thewraith420's Avatar
    ^^^what he said!!
    Tapatalk'n it from my VM670 running LS670ZVJ Hydro Rom
    07-27-2012 05:10 AM
  15. sammyz's Avatar
    ^^^what he said!!
    Look on androidforums same unbrick guide......
    Sent from my Optimus V running Optimus S firmware on MetroPCS
    07-27-2012 08:11 AM
  16. andrewnelson23's Avatar
    Why would we want bootloader? How would that benefit?
    07-27-2012 03:34 PM
  17. mountain2climb's Avatar
    When I click LGNPST File not found?
    07-28-2012 03:51 PM
  18. sammyz's Avatar
    Uninstall /reinstall
    07-28-2012 03:56 PM
  19. thewraith420's Avatar
    Disable anti-virus uninstall then reinstall. I had this problem too Norton thought it was a virus
    sammyz likes this.
    07-28-2012 04:51 PM
  20. mountain2climb's Avatar
    Disabled virus protection. Uninstalled and reinstalled. Still not there can someone please just send me the exe?
    07-28-2012 05:29 PM
  21. sammyz's Avatar
    I don't think that will fix it...
    If you're running windows XP then idk. I can help you via remote desktop connection by teamviewer. BUT try this:
    Enable the Administrator account (This is for windows 7/vista users)
    -Click Start
    -type "cmd" (without quotes)
    -right click cmd
    -Run as Admin
    type "net users Administrator /active:yes" (without quotes)
    type "net users Administrator * " (without quotes)
    Hit enter 3 times
    Log off
    Select the Administrator account.
    From now on you will only use this account for the entire process.
    Because this program has issues when it is not used/installed via the actual Admin account sometimes. Normally install issues and running issues.
    07-28-2012 06:38 PM
  22. sammyz's Avatar
    Just found a better way to unbrick/upgrade by using Software update [KDZ] program
    This will replace LGNPST AND KP500! Only have to install one program that lets the non-installed program run without errors (you still need drivers though). This works fine with any operating system and doesn't need Admin permissions to run either!!
    07-28-2012 07:15 PM
  23. thewraith420's Avatar
    I'll be interested to see this. tho I've just been using lgnpst for my needs.
    07-28-2012 07:31 PM
  24. thewraith420's Avatar
    If you reenabled virus protection after it was installed the antivirus probably removed it again you'll have to leave it off till your done with the program.
    07-28-2012 07:53 PM
  25. sammyz's Avatar
    It finished flashing it, I came from ZVD and flashed ZV5......it wont boot (stops booting at VM logo without sound) and stock recovery won't load...hmmm
    I think I need to add a SCR file to the cab.
    07-28-2012 07:57 PM
140 12345 ...
