Use this instead http://forums.androidcentral.com/op...guide-unbrick-upgrade-optimus-v-easy-kdz.html
because this is obsolete as well as second post.
[INFO]
Things Needed, Downloaded, Extracted:
Install Drivers: look here
Install this program:
Download LGMobile Support Tool 1.5.4.9
Then open the program, let it load, close it.
Download KP500 Tools:
KP500 Utility
Download this ZV5 cab containing VM670ZV5 FW that I fixed to work with KP500 Tool:
ZV5.cab
Extract KP500 to the root of your hard drive, meaning extract everything to C:\KP500-Utils-En
Move ZV5.cab to C:\KP500-Utils-EN[/INFO]
If you have problems following this, watch this YouTube video that asadullah made. Big Thanks to him
[YT]http://www.youtube.com/watch?v=__NUDkxQzEg&feature=youtube_gdata_player[/YT]
[INFO]If it flashes and reaches 99% and fails/stops, check the phone:
1. If it's in recovery, press wipe data (factory reset), then reboot
2. If it is in charge only mode, press power button until it turns on.
3. If it's in the phone, you're done :cheers: [/INFO]
Thanks to Phatninja55 for doing absolutly nothing, and then asking for credit. Just kidding, he helped give me some ideas to get this FW flashing
What I'm working on:
Fixing ZV4 to flash with KP500 DONE!
Please PM me for ZV4 firmware fixed for KP500. DO NOT post in thread asking for it.
Why does LG release borked FW and not able to fix it, but me, a 17 year old is able to?? smh LG.
Anyone know of any other borked firmware from LG? PM me.
Need a kdz to be a cab file? PM me.
Need a cab to be a kdz file? PM me.
Need a wdb file extracted? PM me.
Need an unbrick method for an LG phone? PM me.
Like my work? Did I just save your phone?
Want to do more than hit the thanks button?
Donate here. Thank You
This can also be used if you wanted to downgrade/upgrade/return to stock.
But a better way to do so is in the second post.
[INFO]
KP500 Utility
ZV5.cab
Steps:
Step 1: Download/Install/Extract everything above, it is VERY important that you extract everything to the proper locations.
Step 2: Put the phone in emergency mode:
-Turn phone off, unplug USB, remove battery, reinsert battery.
-Press Volume Down+Back Key+Plug in USB to computer.
Note: Connect USB cable directly into USB port, don't use a USB HUB/splitter!
Step 3: (Vista, Windows 7 users only, skip if running Windows XP) Right click KP500-Utils-EN.exe located in C:\KP500-Utils-EN folder, Click "Properties", click "Compatibility" tab, Checkmark "Run this program as an Administrator", Press Ok.
Step 4: Open C:\ and hold shift while right-clicking KP500-Utils-EN folder and press "Open command window here"
Step 5: Copy and paste these commands (press enter after pasting each command):
If it says to Restart with a pop-up window, unplug USB cable, plug back in, Click Restart.
If it says to Restart without a pop-up window, unplug USB, pull battery, plug in USB, Click Restart.
Code:
KP500-Utils-EN
J
VM670
C:\KP500-Utils-EN\ZV5.cab
ZV5
