08-06-2012 11:18 PM
36 12
tools
  1. Phatninja55's Avatar
    WARNING!!!! This tools is not compatible with CWM-Blue-Recovery any version, it well cause the rom to not install and well trigger auto backup after easing everything, causing the fastboot mode when rebooted.
    @ Phatninja55 I have edit the mean script for the Linux version to flash any rom zip without the need to rename it to update.zip.
    What does the phone do? On the phone when you try it after it pushes the ro to the phone, does it show and android robot with a triangle with a ! in it? If so, that is because the file was was not signed right, or E: status 0, 6, or 7. Has nothing to do with this tool.
    07-30-2012 12:24 PM
  2. Phatninja55's Avatar
    Next version will include nandroid backup and restore. Update will come very soon.
    sellers86 likes this.
    07-31-2012 12:21 AM
  3. sellers86's Avatar
    did you ever figure out those scripts? Im at my computer now and my nook color device blobs have some scripts that involve adb, I can compare if you want.
    07-31-2012 12:30 AM
  4. Phatninja55's Avatar
    I got everything figured out. It was a variable mix up. XD
    07-31-2012 12:42 PM
  5. sellers86's Avatar
    Alright, good.
    07-31-2012 01:22 PM
  6. Phatninja55's Avatar
    Updated post to V2.5.3, Romtools now includes nandroid backup and restore. Let me know if you see any error anywhere. Scripts are now encrypted to protect my work.
    07-31-2012 04:43 PM
  7. sammyz's Avatar
    I'm sure I can guess the encryption code xD jk. How you encrypt a batch? O.o
    Sent from my Optimus M
    07-31-2012 06:47 PM
  8. Phatninja55's Avatar
    Make it into an exe xD
    07-31-2012 08:09 PM
  9. EarthnFire78's Avatar
    All my roms are signed properly, otherwise BacksideUpdater's auto install would not function right. My CWM-Blue-Recovery does a backup of the current rom before installing either updating or fresh install. Because of that it fails to push the rom zip to the data partition. The way around the is to remove the "easy_image" from the script in Romtools and/or editing the updater-script to do the formatting. I could also go through the Recoveries Source Code and try making it compatible.
    08-01-2012 06:26 PM
  10. Phatninja55's Avatar
    I will consider removing erase_image in the next version. I've had to pull the downloads because it wasn't working right.
    08-01-2012 06:41 PM
  11. cole2kb's Avatar
    Thread closed.
    Since I'm to lazy to continue this, I will be asking for this to post to be removed. Plus RomManger soon shall be compatible with out phones.
    08-06-2012 11:18 PM
36 12
