[ROM][WIP][ZVJ]Cross Bread Gingerbread
Status
Not open for further replies.
jonny5449
AC Citizen
Dec 14, 2011
2,553
286
Hello all this is sort of a discussion thread for my upcoming rom will add downloads when finished but for now its just discussion
Hello there welcome to cross bread gingerbread this is a rom based off of jtsnp stock rooted base rom .
This is meant for OPTIMUS V ZVJ DONT FLASH UNLESS YOUR ON IT!!!!!!
Flash at your own risk
What this is and not
This is a tweaked rom for the optimus v
This is tweaked for performance
This is NOT created by me​
Now here are the features
Amphetimes
Adrenaline engine
Beats audio+xloud
Themed
Good battery life
Removed boot sound
Better launcher
No sprint stuff
Build.prop tweaks
Deleted some things not needed
Htc-ime keyboard
Thanks
Torch2424-inspiring me
Jtsnp-base rom
Sammyz-for OV zvj
RedBaron-for your tweak
Dhruv.always-pm'ed u a couple times this month no reply I included ur beats if you don't want me too I will take out :D:D
Me-for tweaking
ThatGuyLurkin-teaching me about everything I know he's like a Jedi master I'm a apprentice :p:p:p
Hlxanthus-for htc -ime keyboard idea
http://forums.androidcentral.com/showthread.php?t=170067
Imbawind-adrenaline engine. http://forum.xda-developers.com/showthread.php?t=1604315
I will give out test builds soon but for now no downloads until I'm done with it
Also the tweak for switched basebands may not work
Pleeeease flash hydro kernel I want u too lg stock kernel suckz
Here it is
http://forums.androidcentral.com/showthread.php?t=167942
Or iscream kernel your choice
http://forums.androidcentral.com/showthread.php?t=156698
Also here's ginger kernel
http://forums.androidcentral.com/showthread.php?t=114652
Kernels are optional but recommended since these you can OC your phone with
Try the patch in this thread if your on zv4 ect all the way to 9
http://forums.androidcentral.com/showthread.php?t=194211
How to install
Reboot recovery
Backup
Wipe everything
Disable signature verification
Flash rom
Flash kernel (please or it WILL be slow)
Reboot
Profit
Give me thx or likes :p:p:p:p:p:p
Flash this for extended power menu
http://forums.androidcentral.com/showthread.php?t=168335
Just wipe caches:p:D
Will try to get permission to include
Download-today or tommorow
Bugs:(:(:thumbdown::thumbdown:
When you first boot up you get a fc with update something I'm on it
Sorta slow without hydro kernel
Can't download zip files it WILL say....download failed or something:(
That's all:D:D:D
Sent from my LG-LS670 using Android Central Forums
jonny5449
AC Citizen
Dec 14, 2011
2,553
286
jonny5449
AC Citizen
Dec 14, 2011
2,553
286
Can anyone help me out?
I replaced the keypad folder I got OS buttons
I replaced usr folder got OS buttons can anyone help thx after that I will give out tests
Sent from my VM670 using Android Central Forums
ThatGuyLurkin
2,155
665
Please don't include any Beats stuff. :'(
Sprint Gingerbread has WAY better sound quality than IHO and CM9.
Adrenaline Engine, isn't that just the terminal command. Basically, a ' task killer '.
Also, Release Test Builds in public. o_O
jonny5449
AC Citizen
Dec 14, 2011
2,553
286
As you wish
As soon as I get buttons I will release build
@sellers
I understand
@everyone
I can release it but will have wrong buttons maybe the patch will work????
Reactions: inceyet
andrewnelson23
795
145
if you tell him how to do it, he's learning, right?
this rom is zvj....but there's like a total of maybe three people on zvj right now. haha
sellers86
1,837
617
No, you misunderstood me. He can ask, but he keeps asking people to do it for him. Thats not learning.
andrewnelson23
795
145
You need to go to /system/usr/keylayout. Then choose thunderc_keypad.kl and edit the keys in there. you just need to switch the home and menu buttons.
sammyz
825
190
Look at nitestalkrs patch, it is a single file you replace....not an entire folder.
Sent from my Optimus V running OSZVJ firmware on MetroPCS using HydroROM.
Reactions: nitestalkr
jonny5449
AC Citizen
Dec 14, 2011
2,553
286
Well will do the key thing tommorow thanks guys I will add you to thanks
Also when you flash rom flash hydro kernel because the lg stock kernel sucks I will do key switch and a couple other things and I will give out or release test build
Also I made an s version too
ThatGuyLurkin
2,155
665
If you made a S version, you should remove " Tweaked for the Optimus V " :p
And please release test in comments. xD
Use the keylayout from the patch Nitestalkr made. Just copy the folder over in winrar, no need to copy individual files. It works for me.
jonny5449
AC Citizen
Dec 14, 2011
2,553
286
They are sorta different
Status
CrystalLewis
